Old 31-07-2007, 12:16 PM   #1 (permalink)
lalam's Avatar
Default Need help with my HDD
I recently purchased a new hard disk drive and what i want to do is set it to be the main boot hd (primary). I've checked with the jumper settings but when i do so and try to install the os in the drive it only shows me 32 point something gb of space (its 160 gb actually). I want to know what should i do to get it to run as the main hard drive from where my os runs. The old hd i have is of 80 gb (Hitachi) and the new ones 160 gb (seagate). Please help.Thank u in advance.
lalam is offline
Old 31-07-2007, 05:38 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Need help with my HDD
does ur motherboard support THAT much capacity HDD [160gb] ???
checkup ur manual .........
... W H O T ...
ax3 is offline
Old 31-07-2007, 05:50 PM   #3 (permalink)
Search for Adventure
ITTechPerson's Avatar
first check if ur mobo support 160 or upper then also see ifu have set the jumper in proper position.
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 31-07-2007, 11:07 PM   #4 (permalink)
lalam's Avatar
Thank u guys already got around with this problem....
lalam is offline
Old 01-08-2007, 05:52 PM   #5 (permalink)
ax3
ax3's Avatar
whot was THE actual problem ???
solution 2 ???
... W H O T ...
ax3 is offline
- by kool
