Old 31-07-2007, 11:37 AM   #1 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Default Pls guide.....
Hi all....first of all a hearty "thanx" 2 evry1 who has spent valuable time in answering the issues n troubleshooting discussed here....if it were nt for u guys, ppl like me wud hav had to search the net for hours n still cum up wid a fewer results thn xpected....so thanx again...i really found the threads useful n they throw in a lot of knowledge easily makin ppl like me fit for the "Techno-Geek" title ....Anywz....i had a small query....i own an AMD 64 3000+, MSI RS480M2-IL mobo wid 1GB DDR(512*2) n all this on a 400w pwr supply....i have been facing this peculiar prob since long...after sum time of pc operation my pc starts stuttering...even the mouse movement at times gives jerks wen moving around on the desktop....nd i guess its related to heatng coz this happens mostly wen the ambient temperature is high or after starting 3ds max or sum games like nfsmw, etc....even the songs played on winamp strt stuttering aftr sumtime.....but this doesnt always happen...wud a thermal cooler b of any help????? cuz i dont wanna invest 3k in a cooler if heating is not the culprit....pls guide
Also, i plan to go for 8600gt 256mb or 7600gt 256mb.....wich one is gud....nd wil both suit my system in terms of temperature n compatibility????
_____________________________________________
AMD Phenom II 920__GIGABYTE GA-MA78GM__1.75TB HDDs__6GB DDR2__CORSAIR VX550___ZOTAC GTS 450 Amp Ed!!___Samsung Syncmaster B2230__DELL INSP 15
sid_sh85 is offline
Old 31-07-2007, 11:40 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Pls guide.....
Man, first put forward your query in seperate sentences, will be easy to read.
Anyhow, firstly what are the current temps?
If there's dust clean it, do some cable management to have a proper air flow. How many fans and in what orientation?
Those AMD 3000+ (I think its venice core) rarely have heating issue at stock frequency. Maybe try a different PSU (if possible) and see if the problem is solved.
john_the_ultimate is offline
Old 31-07-2007, 11:48 AM   #3 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
oh...i kno i guess i hav made the issue too compilcated...but u see...thts my desperation for a solution...anywz...idle temp for cpu is 61 deg n sys temp is 43deg....
sid_sh85 is offline
Old 31-07-2007, 11:53 AM   #4 (permalink)
No pain....No gain
Idle temps of 61C
Remove the HSF, clean it, put a fresh layer of thermal paste and see if it helps. I had amd 3000+ which was overclocked to 2.5GHz and had a load temp of 54c.
And as said earlier, clean the inside.
Old 31-07-2007, 11:55 AM   #5 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
oh...u mean "HEAT" is the culprit here....ok will do dat soon n keep u posted...anywz..regarding the 2nd query abt graphics card, wht do u hav to say????
sid_sh85 is offline
Old 31-07-2007, 12:06 PM   #6 (permalink)
No pain....No gain
Get 8600GT (DirectX 10) from brands like XFX, Leadtek, Zebronics no point in getting 7600GT(DirectX 9) card.
Which PSU have you got?
Old 31-07-2007, 12:08 PM   #7 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Well thanx for the gprx card suggestion.....my dealer is quoting abt rs6000 for 8600gt256mb....anywz sory to ask dis but wht do u mean by a psu????
sid_sh85 is offline
Old 31-07-2007, 12:10 PM   #8 (permalink)
No pain....No gain
PSU = power supply unit or SMPS. 6k for 8600gt is a good price, which brand?
Old 31-07-2007, 12:24 PM   #9 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
ok...m using 400w psu....n xfx 8600gt for 6000rs...
n dude...wich thermal paste...pls specify the cost n brand
sid_sh85 is offline
Old 31-07-2007, 12:43 PM   #10 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
I suggest u use a good power supply with the 8600 GT ur gonna buy
Harvik780 is offline
Old 01-08-2007, 02:43 AM   #11 (permalink)
No pain....No gain
Get atleast colorsit, powersafe PSU 500W for around 1.5k andas for thermal paste get Arctic Silver 5 (don't know its price but its one of the best).
Old 01-08-2007, 10:48 AM   #12 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Thanx a lot man...wil buy it all soon
sid_sh85 is offline
Old 01-08-2007, 01:31 PM   #13 (permalink)
tech mighty
arun_chennai's Avatar
XFX 8600GT for 6k..... from where u r getting that? very good price!!!
arun_chennai is offline
Old 01-08-2007, 01:45 PM   #14 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
frm my regular vendor....mumbai
sid_sh85 is offline
Old 01-08-2007, 02:42 PM   #15 (permalink)
Pain is Forever
rohan4pal's Avatar
hey man where in mumbai??????????? plz tell me
If it's true that we are here to help others,
Then what exactly are the others here for?
rohan4pal is offline
Guide me for a new PC vivekr QnA (read only) 3 19-04-2007 02:34 PM
SE user guide or useless guide, wat u say. Destruction Mobiles and Tablets 8 21-03-2007 09:41 AM
Guide to BCA and MCA. DeSmOnD dAvId QnA (read only) 1 24-03-2006 03:49 PM
AMD guide sagargv CPU / Motherboards 1 03-01-2006 09:56 AM
- by kool
