Old 30-07-2007, 12:55 PM   #1 (permalink)
Default Athlon 64 X2 3800+/4000+
i need to buy amd dual core processor...i read all the rewievs on google but m confused shoud i go for 3600+, 3800+ or 4000+ ...
chinmaythakur is offline
Old 30-07-2007, 12:56 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Athlon 64 X2 3800+/4000+
if ur budget is less and their is a major price diff. between all the three then go for 3600+...
3600+ runs at 1900 MHz
and
4000+ runs at 2100 MHz... so their wont me much processing speed difference.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 30-07-2007, 04:28 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Athlon 64 X2 3800+/4000+
Agree, as now all comes from new core and same 1MB L2 so, 3600 wont lag a lot behind of 4200,
also, may be u can refer here too, http://www.thinkdigit.com/forum/pc-components-configurations/71700-basic-guide-purchase-new-system-post559529.html
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 30-07-2007, 05:22 PM   #4 (permalink)
Google Bot
Pathik's Avatar
make sure u get a 65nm proccy... pref 4200+
Pathik is offline
SMPS for Athlon 64 X2 3800+ Golumolu Hardware Q&A 7 15-05-2007 06:02 PM
pentium d 930 vs. athlon x2 3800+ ramana321388 Hardware Q&A 6 05-08-2006 06:59 PM
- by kool
