Re: A good gaming MotherBoard-CPU combo suggestion required.
for gaming , u need a dedicated gpu .
so go for C2D and buy a g-card based on ur budget. If ur budget is restricted , then amd may provide more bang for buck . thats upto u and it depends a lot on ur budget and whether u want to OC ( i dont c any reason y u dont want to OC a C2D ) .
but in either case , u need a dedicated gpu for gaming. So , Wats ur budget ?
