29-07-2007, 01:38 PM
"The Gentleman"
USB entension cable
i hav bought an usb entension cable for Rs.30... my system detects it and balloon msg appears that a " Usb Device found " and then when i connect a pen drive... it says unknown device found & pen drive is not detected... should i install some driver for usb entension cable ?? my pen drive works fine when i connect it directly without using entension cable... cable is also new and their is no fault in the calbe.... but how do i get it work ??
2.) in case if the usb entension cable is working.... will it give a speed of USB 2.0 ??? if no then how to get that speed in usb entension cable. ??
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
29-07-2007, 01:43 PM
Re: USB entension cable
how long is ur cable?? .. if its somewhere near 5m long it probably wont work!!
I think it'll give speeds little less than USB 2.0 speeds, depending on the make!!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
29-07-2007, 01:51 PM
"The Gentleman"
its
48 inches = 128 centimetre = 4 feet .... long.
it cost me Rs. 30
now tell me ??
- Dijkstra
29-07-2007, 02:01 PM
oops!!!
sounds kinda 2 long 2 me
not enuf power travellin' dat distance
29-07-2007, 02:02 PM
hmmm.. acc to me it has to work...
How do you kno dat??
29-07-2007, 02:03 PM
"The Gentleman"
already exchanged the cable that is why i'm sure abt it.
- Dijkstra
did u by any chance chk it out @ d shop
was it workin der
if not den u may consider replacin it wit a 1.5-2[max] ft cable
29-07-2007, 02:05 PM
"The Gentleman"
was it workin der
i checked the cable in home... but cable gets detected and not d pen drive.  i get an error msg " unknown device found "
- Dijkstra
well.. my 3ft one works fine without any hassles.. (got it for 25 bucks from National Market Bangalore) ... So 4ft may work out!!
29-07-2007, 02:07 PM
"The Gentleman"
i got it from s p road. did u install any drivers or something ???
what is d speed ur getting ?? is it usb 2.0 ??
- Dijkstra
29-07-2007, 02:10 PM
No drivers required.. (Atleast on my XP.. dunno bout older versions)
i dunno if its USB2.0.. Its a local one without any kinda packing..
29-07-2007, 02:22 PM
"The Gentleman"
i too had a normal packing with just a plastic cover.
me using winxp sp 2 .... dont know wtf d prob is
- Dijkstra
29-07-2007, 02:24 PM
U cud've bought it from a known source..
29-07-2007, 02:47 PM
y dont u take d ext cable and ur flash drive 2 a diff comp and chek it out, and if doesn't work der take both back 2 d shop and show him ur prob and ask 4 a 3ft 1 dat sam mentioned
@sam_1710
1 ft can cause considerable diff buddy
29-07-2007, 02:51 PM
^^^ .. its speeds arent USB2.0 speed.. but it recognises the devices easily!!
29-07-2007, 02:54 PM
Still Shining!
USB Extension Cables don't get "detected" on their own when connected to the computer. You have to connect a device at the other end. MAybe, your Pendrive has got some problem with the cable.
I have connected 4 such cables each of length 2 metre end to end to make it a 8m long cable and connected a webcam to the other end, so that I can use it like a video camera  . And there is no problem in the working of the webcam. Nor any slow transfer speeds.
Maybe you should connect it to different ports on the backside and see.
Nokia N86 8MP
29-07-2007, 03:15 PM
"The Gentleman"
now i tested with my usb keyboard seems to be working fine with the cable except for d kingston data traveler 2.0 pen drive.... i checked on the other comp also, even their its showing the same error "unknown device" but pen drive has no problem when connected directly. seems a little strange prob at this end.
@ lucky star, wats d speed ur getting for web cam (usb 2.0) ?? since ur cable is too long.
- Dijkstra
29-07-2007, 09:20 PM
strange nahi yaar!!!
its just dat d keyboards power requirement is lesser dan dat of a flash drives
so d reduced power dat is supplied by d exrended usb cablu is enuf 2 run d keyboard but not d flash drive
29-07-2007, 09:34 PM
#19 (permalink)
D i s t i n c t l y Ahead
i am having ubs entention cable apx. 4 ft length but its working fine
29-07-2007, 10:11 PM
#20 (permalink)
Still Shining!
Well, I don't know the exact speeds. But the webcam works the same way when I connected it directly to the computer without any cables.
No lags in the video.
Once I had connected my PD to it. and there was no deterioration in transfer speeds.
Nokia N86 8MP
31-07-2007, 12:24 PM
#21 (permalink)
Cool as a CUCUMBAR ! ! !
no problem @ my pc 2 ........ i 2 have 2 such cables ........ bt working fine .......
detects even my usb drive [ext hdd], pen drive & many more .......
check ur pen drive for problems ...........
... W H O T ...
