Old 28-07-2007, 10:03 PM   #1 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
Default Recommend The Best CRT Television In Rs.25,000 Range.
Well as the title says , i am looking for a 29" CRT television in the range of Rs.25000/- I would like to know from your personal experience which brand is BEST in performance? Sony, Phillips, LG , Samsung, or something else?
preference order would be
1>performance
2>build quality
3>price
EDIT: If possible please mention product number.
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 28-07-2007, 10:08 PM   #2 (permalink)
24online's Avatar
Default Re: Recommend The Best Television In Rs.25,000 Range.
i think sony and samsung r best.....no problem.... lifetime enjoy..
**#(o)#**
24online is offline
Old 28-07-2007, 10:16 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Recommend The Best CRT Television In Rs.25,000 Range.
Last durga puja, we bought home this Samsung 29" flat tv (Model Number:CS-29K44ML). Its cost was 16500 then. And its working perfect. The picture is crisp and sharp and the colours are vivid. I like its design the most. Its the most sexiest 29" from Samsung. It has DNIe vision whihcmakes the picures sharp at the edges of the screen. There is an optional Subwoofer model also which will cost you some 2500 bucks extra. But I would suggest you to buy a separate speaker set like Altec Lansing ATP3.
There are models from sony too. But after comparing the both, I saw that samsung outperformed sony here. So chose Samsung.
Nokia N86 8MP
Lucky_star is offline
Old 28-07-2007, 10:16 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
One may allways consider LG XD Range 25" models
http://www.lge.com/products/tv/XDEngine/index.htm
I saw some on display at a LG Showroom, will be under the budget of Rs. 25k for sure...
Pictures are stunning
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 28-07-2007, 10:17 PM   #5 (permalink)
slugger's Avatar
bben usin a 29" Sony CRT 4 d past 1 yr
pic/sound qlty ROCCCCKKKKKKKZ
dont look beyond Sony wen buying TVs
performance and service absoultely impeccable
[actually service is not an issue, 'cause my last 21" Sony needed just 1 visit 2 d service center in almost 14 yrs]
BUY A SONY !!!! d others leave a lot 2 b desired. they spend more on ADs dan R&D
remember dat d Japs r d pioneers [dey still r] d koreans simply do catchin up, but never succeed
slugger is offline
Old 29-07-2007, 08:04 AM   #6 (permalink)
thrash_metal's Avatar
Sony if you think its worth the premium , Samsung for value for money !
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 29-07-2007, 04:31 PM   #7 (permalink)
King of my own Castle
freshseasons's Avatar
Frankly i will suggest the none.
This is really no time to go in for the CRTs .Especially High End ones.
The prices of LCDs and Plasmas are really falling down every month.If you can just hold on for another month or so ,and then go for a LCD it will be worth it.
Nothing like veiwing the glory of HDTV and all that is bound to hit indian markets sooner of later.
Moreover TV is almost for atleast 5 Years.I mean though you do tend to buy as they come but the old ones which are few years old are rarely disposed.
So i think its better you opt for LCD even if you have to increase the budget a bit.
freshseasons is offline
Old 29-07-2007, 06:38 PM   #8 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
^^^ He is right!!! Its no time to buy a CRT coz its LCD all the way but if u really wanna buy CRT tv then only SONY is the best option. I 've bought SAMSUNG 29" TV and i got what i paid for. In LCDs SAMSUNG is good but when it comes to CRT TV, SONY steals the deal for sure.
keith_j_snyder2 is offline
Old 29-07-2007, 07:11 PM   #9 (permalink)
a_k_s_h_a_y's Avatar
i think for 30k u will get a 32 LCD videocon that is
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 29-07-2007, 07:18 PM   #10 (permalink)
left this forum longback
praka123's Avatar
does any luck this yr that lcd(+19") TV get below 20000rs
praka123 is offline
Old 29-07-2007, 08:36 PM   #11 (permalink)
Turn The Page
pannaguma's Avatar
thanx a lot for your replies. The thing is that LCD tvs have very low value for money right now, and my present tv is very-very old. So no point in waiting for HD tv's whose content will take 3-5 yrs to hit the indian market.
So it seems most people suggest a SONY WEGA. But the thing is after comparing models from SONY, LG, SAMSUNG, PHILLIPS i have two points against SONY:
1>they are upto 40% higher priced than the competition
2>a 26k model(29") ( http://www.sony.co.in/product/kv-fa2...ite=hp_en_IN_i ) doesnt have
a)Digital Noise Reduction,
b)100Hz Progressive Scan,
c)support for HD input.
Which certain models from LG, SAMSUNG, PHILLIPS offer for a lesser price. The sony model having these features is priced 37,000 (). Also in last month's PC WORLD this PHILLIPS model was given the BEST BUY award: http://www.consumer.philips.com/cons...CSHQNHKFSESI5P
It also has the three above mentioned features.
So the question is should I go for Sony only based on brand value and buy a higher priced/low feature TV, or should I buy one from these ???:
SAMSUNG: http://www.samsung.com/in/products/t...cs_29t10pa.asp
LG:
http://www.lgindia.com/Product/Produ...d=86&Proid=667
PHILLIPS: http://www.consumer.philips.com/cons...CSHQNHKFSESI5P
I found more about this model here: A look in to Philips 29" HD-CRT
Please comment.
Old 29-07-2007, 09:01 PM   #12 (permalink)
slugger's Avatar
how d HELL did u make d page scroll horizontally!!!!!!!!
plz dont do dis in future post
slugger is offline
Old 29-07-2007, 09:08 PM   #13 (permalink)
Turn The Page
pannaguma's Avatar
i didnt do it on purpose, i didnt use hyperlinks, so the page is extending horizontally to display the long links. Sorry dude, but dont know why it bugged u so much.
EDIT: on second thought, it should automatically shorten direct links, by the dots. but its not happening, so dont blame me.
Old 30-07-2007, 01:33 AM   #14 (permalink)
Rising ApocalypsE
Well i still believe that SONY is the best.Like we have an old saying "Mehnga roye ek baar aur sasta roye baar baar"
So don't compromise over the quality.
Dude u can get a 29" TV for 10-12K from AKAI, SANSUI etc. but i 've seen this..
I have a SONY CTV which is almost 22 years old but its still running smooth but one of my friend is having some brand...not sure about it(soon will tell u) and he bought it 2 years ago & still at the service centre from since last month.
Old 30-07-2007, 03:15 AM   #15 (permalink)
praka123's Avatar
^ur friend's the brand ur saying will be samsung ofcourse or akai or tcl
For me my Sony KV-J21MF1AK Kirara Bazzo survived two lightning attacks came via cable and power point(of course got it repaired!) -SONY any time.
But Philips too is a good brand.
praka123 is offline
Old 30-07-2007, 11:03 AM   #16 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
1st don't get carried away with hd ready label with philips HD Ready 29PT8836/94
look here
Don’t Buy Hdtv Before U Read This
next if u just wanted a damn good crt sdtv then nothing comes near to 29PT8836/94 in terms of price : performance ratio just go & get it
i have both lg 29" fd55ve & wega 21" so i can say lg29" is also a good choice for its price
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 30-07-2007, 12:11 PM   #17 (permalink)
ds_rajat's Avatar
We have SAMSUNG 29" & AKAI 29". Sales & service for AKAI provided by VIDEOCON.
I must say it's really a very good cheap TV. Range starts from 12,000/- for
29". Best value for money. Very nice picture & sound.
My PC My World
ds_rajat is offline
Which 32" LCD television? vikramk Hardware Q&A 20 26-01-2009 10:48 PM
Recommend best Mobo for C2D and Quad C2D in price range of 9K to 14K ramu Hardware Q&A 3 17-06-2007 07:08 PM
Suggest a Good 29" Television in range of 15 - 25k sbhas2k QnA (read only) 2 28-11-2006 09:04 PM
Problem connecting to television... mario_pant Hardware Q&A 12 16-12-2005 03:53 PM
connect P.C. to Television slugger QnA (read only) 7 02-09-2004 09:42 PM
- by kool
