Re: need help plzz brought a lcd for my p3 but the picture quality is vry bad
Hi @hackers2005.3721
Hi.. I bought an LG 1753s. I presume that your problem is the display is appearing with more glare. i.e., the yellow folders in windows are looking too gaudy? press the menu button and go to the last option on the right. Now, on the left menu, pass the first set of options(language, position etc...) on the next screen, you will have 'WHITE BALANCE'. Press 'down' or 'up' here. the screen adjusts. You might need to do this more than once. You will see correct display. If the screen doesnt stay in correct display mode, do the factory reset and then repeat the white balance and factory resets until u get the desired display. After this, try with a screen lock. Atleast this is what I did to get the work done on my lcd. I saw the high specifications on the site and went for this but I got little disappointed. the red color sometimes looks too glary on my screen.. Hope this helps....
vbmenu_register("postmenu_561179", true);
