Old 28-07-2007, 03:55 AM   #1 (permalink)
Default System Hangs at night!!1
pals...
i recently purchased a new sys....
3800+ x2
2x1gb ddrII - 667
asus m2n-mx
160gb x2 hdd
vista ultimate...
my system runs....from morning 10am till next day morning 7am. continuous...
but after my new system is been installed....and functioning....
my employes r complaining abt,,system starts hanging at night after 12 or 1.... y so?????
the system starts hanging,,,responds slowly.... and network slows down????
help needed urgent...
thanx
angel
The Day Walker! is offline
Old 28-07-2007, 10:10 AM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: System Hangs at night!!1
This has to something with heat. INcrease the airflow in the cabinet. REduce the clutter (of wires) in the cabinet.
Older AMDs (Athlon XPs) had this problem of hanging even in the slightest occasion of heat. But with X2s this problem did not occur. In your case, it has to be heat as it runs for so long continously.
cynosure is offline
Old 28-07-2007, 01:26 PM   #3 (permalink)
didnt had this problem with my 3000+ 64bit
it ran same as this rig does.....
never hang........ but this rig hangs.....?????
and if its the heat prob......then wot r the necessary steps 2 bn taken....
i already have 2 chasis fans installed.......
no more place 2 install any more chasis fans......
if a cpu cooler does better then which 1 should i get ... budget - 2000
thanx
angel
Old 28-07-2007, 02:32 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
its the ghost.... ......they get activated in ni8 at 12 .....
first reatcion is that its heating problem.....
Check ur pc for viruses and trojans...if ur connected over net then it can be that problem......
run memtest and check ur ram modules...
wizrulz is offline
Old 29-07-2007, 01:24 AM   #5 (permalink)
1. my pc has never been connected 2 net.....
2. i regularly update my a/v with the latest def.. from home....
3. ran memory tests...nothing fishy.....
so i think its the heating......
which cpu cooler is good enough 4 my case.... no oc...just normal usage...
only photoshop full time........ budget:- 3000 max
help needed...
thanx
angel
System hangs..help linardni QnA (read only) 3 10-02-2007 03:59 PM
system hangs and doesn't start callmeastha Software Q&A 7 26-08-2006 04:36 PM
search system hangs!! gary4gar QnA (read only) 2 23-02-2006 01:27 PM
system hangs frequently legolas QnA (read only) 7 26-10-2005 10:04 AM
HELP!!! SYSTEM HANGS TOO MUCH hsnayvid QnA (read only) 26 21-04-2005 05:27 PM
- by kool
