VX2235WM is better but also costlier. And what's normal height thingy? Both are 22", right.
E228WFP...i ordered 1 for 19k from dell its gonna be here in a day or 2..Its definitely better than VX google it n check the reviews..it also supp hdcpi..and a greater screen area..lesser bleeding thn d vx! CHEERS!!
VX2235Wm has got newer TN (6-bit) panel, which could display 16.2 colors. But if you go by price to performance ratio and include the looks factor then go for Dell. It does look better
It means that most TN panel are 6-bit but these newer ones simulate 8-bit panels by 6-bit + 2 bit dithering method.
So, basically a 8-bit panel can display 24-bit color but 6-bit TN panels cannot.
For more info about LCD panels read this : http://en.wikipedia.org/wiki/TFT_LCD
no no dear i meant it in comparision to dell
knowledge can be shared & must be BUT intelligence CAN'T be
Well the pictures did seem better with VX2235WM (my friend has it) but I would still prefer Dell, better appearance also cheap.
@ vivek
I had read that review and the monitor certainly looks great.
