| Forum |
#1 (permalink) |
at the taskbar.The game launches back whenever i click that minimised tab at the taskbar and runs smoothly.Then again after 10 minutes,the same problem occurs.I bought my new pc some four months back.This problem occurs with every game that i run, be those be new games like double agent,fear,ghost recon,blood money, or old games like mafia. plz help. my system specs: intel[r]core[tm]cpu,1.86 ghz with 2gb of ram intel d965 motherboard nvidia 7900 gt/gto gpu. my os is windows xp home edition with service pack 2 installed. my graphics card drivers are up to date |
#2 (permalink) |
also install d latest DirectX end-user runtime available
den c wat happens just 2 b safe reinstall d games also actually it has dawned on my mind dat it cud b some proggy dat is starting causing it 2 minimise [basically stealing focus from d runnin proggy]. c wat proggies r runnin in d b/ground ,maybe sum anti-* or updater/schedular |
#4 (permalink) |
press ctrl+alt+del and end processes that u dont trust ( under ur username ) . do a spyware scan . . its probobly the problem . re-installing OS will surely solve the problem if u have the time and patience..
C2D e7500 @ stock, gigabyte G41 , 2gb ddr2 800Mhz , Seagate 500GB 7200.12 , xfx radeon 4770 , lg dvd-rw , cooler master extreme power plus 500W , altec lansing vs4121 , dell sp2208wfp 22" |
#5 (permalink) |
Thats wierd.I have the exact same configuration & don't seem to have any such problem.In fact I just got the card 3 days back & have been trying every possible game out centre,left,right & round without any minimising issues like you mentioned.The only problem I have is with resolution of some games wherein they won't have 1280x1024 resolutions & hence I end up either setting them to 1600x1200 with max settings or 1280x960 max settings.Eitherways the side portions of my monitor gets cut out & hence leading to those black bars coming up which is seriously begining to tick me off.Tried every possible refresh rate but they just don't seem to work.
Try installing a fresh copy of XP.Did you uninstall your old Intel driver before turning to the Nvidia ones?
"Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof. " V for Vendetta |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Display gone bad! Plz help. | harmik | Hardware Q&A | 20 | 22-06-2007 02:02 PM |
| Help needed regarding display problems | abhi_alpha_beta | QnA (read only) | 3 | 07-08-2006 06:43 PM |
| Problems on Samsung 740N display | sniper | Hardware Q&A | 2 | 07-08-2006 04:13 PM |
| DISPLAY PROBLEMS | ravitejap | Software Q&A | 1 | 07-02-2006 09:26 PM |
| Display Problems | justfriendz | QnA (read only) | 5 | 20-09-2004 01:32 AM |
