Old 27-07-2007, 08:20 AM   #1 (permalink)
Sangeet Premi
2kewl's Avatar
Default Suggest a DVD Writer!
Suggest me a good DVD writer, Guys..Planning to buy one!
Pls specify the price as well!
2kewl is offline
Old 27-07-2007, 08:31 AM   #2 (permalink)
UbuntuUser
cynosure's Avatar
Default Re: Suggest a DVD Writer!
I am using Lite-On LH-20A1P. The price is ~1600 in Nehru Place, Delhi.
Some people here in the forum had a problem that the model did not read the dual layer DVDs. But updating firmware was the solution and after that the model did quite well. But I must say I never had any such problem, my burner is going strong even after 1.5 months and it can read dual layer without any problem. I have already burned around 50 DVDs using it, never had any burn error.
I would give a green signal is you were to buy this model.
cynosure is offline
Old 27-07-2007, 09:17 AM   #3 (permalink)
Sup' dude, Sup'
Support is worst for liteon. and failure rate is high. better go for sony
ambandla is offline
Old 27-07-2007, 09:34 AM   #4 (permalink)
56561's Avatar
Go For Sony . Basically Liteon Makes The Dvd Drives For Sony . They Also Sell Their Own Brands. So In The Market You Will See Both Liteon & Sony Which Are Made By Liteon . But Liteon Makes Good Models For Sony And Somehow A 'low Priced' Models Under Its Name .
So Go For Sony . Liteon's Support Was Bad . And Failure Rate Is High.
Now Rest U Have Samsung , Lg , And Paxtor .
56561 is offline
Old 27-07-2007, 12:37 PM   #5 (permalink)
Swalpa Adjust Maadi
RaghuKL's Avatar
Please keep in mind that "some" Sony models may not be able to read the dvds which may be written on other writers..
My Sony DRU 830a has similar problems . Maybe u shud try LG writers
if you have noticed this notice you will have noticed that this notice is not worth noticing
TRUTH IS OUT THERE
Do right and fear no man.
In word without walls, is windows (7) really needed?
RaghuKL is offline
Old 27-07-2007, 01:10 PM   #6 (permalink)
Cool G5's Avatar
Arrow Re: Suggest a DVD Writer!
Go for LITEON LH-20A1P.Good DVD writer.I too have not yet faced any major problem with it except the Dual layer DVD problem.(U can fix it by firmware,so no probs).Also it supports 20x DVD writing.At Rs.1.5K,it's great value for money.I have burned around some 20~25 DVD's & around 200+ cd's on it.No probs at all.
Cool G5 is offline
Old 27-07-2007, 01:23 PM   #7 (permalink)
King of my own Castle
freshseasons's Avatar
Get a Asus LightScribe one . Very Stable AND fast! Say bye to costers forever.
freshseasons is offline
Old 27-07-2007, 05:49 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
sony AW-170A is also good ................. using it 4 quite some months ........ no problem @ all ..........
... W H O T ...
ax3 is offline
Old 27-07-2007, 06:53 PM   #9 (permalink)
lite on 20x .. anyday .. got one for 1475rs here in mumbai
yogi_7272 is offline
Old 27-07-2007, 07:43 PM   #10 (permalink)
tech mighty
arun_chennai's Avatar
go for Lite-on.........
arun_chennai is offline
Old 27-07-2007, 07:46 PM   #11 (permalink)
[Next-Gen]
Hustlerr's Avatar
Yup... Lite-On LH-20A1P, I m also using it and never got any error by it
i5 2500K | P8Z68-V Pro | G Skill 8 GB 1600 | MSI R6950 Power Edition | Seagate 1.5 TB | Dell ST2220L | Logitech MX518 n K200 | Cooler Master Elite 401 | Corsair TX 650 | Windows 7 x64
Hustlerr is offline
SUGGEST DVD Writer maddy_4rocks QnA (read only) 6 12-08-2006 09:26 AM
suggest me the best dual layer dvd writer thinktwice Hardware Q&A 6 14-07-2006 12:54 AM
DVD Writer Help !!! dreams QnA (read only) 1 05-02-2006 08:21 PM
suggest external dvd-writer! .:;AddICtEd;:. Hardware Q&A 4 09-01-2006 03:17 PM
suggest me good dvd writer smilingguy Hardware Q&A 12 08-01-2006 02:03 PM
