Old 26-07-2007, 06:13 PM   #1 (permalink)
tango_cash's Avatar
Default "Intel recommends the use of a 2x12 power connector or a 2x10 power conector...ERROR
hi my computer gave the following error message when started.
it was too long to note down so i took some pics of the screen and joined them.
se the picture below.
my config is
cpu - 2.8gz intel hyperthreading
mobo - 915 gav intel orignal
250gb sata segate harddisk
intex cabinet with colorsit power supply.
now i had 2*256=512mb ram of hynix.
i recently got 1 256mb ram of DYNET company.
so i installed it also with the other two.
i have 4 slots for ram in my mobo and it supports upto 4gb ram.
one slot is empty and remaning 3 are occupied by the 3 256mb rams.
all of these rams are of 400mhz (atleast that's what is written on there labels)
i have bought a transcend jetram of 1 gb ddr400. i want to install it in the 4th slot so that will make my total ram 1768MB. but just when i was thinking of opening my cabinet and installing the new ram this error came.
however my systen started when i "pressed any key" at the message and after that i have restarted my system 2-3 times and the error has not come up.
Now i hear a beep everytime the system starts
what was that message about. pls help me.
Intel recommends the use of a 2x12 or a 2x10 power connector in conjunction with the 1x4 alternate power connector
and if want any more details pls tell me.
Last edited by tango_cash; 27-07-2007 at 01:46 PM. Reason: "Intel recommends the use of a 2x12 power connector or a 2x10 power connector in conjunction with the 1x4 alternate power connector" error
tango_cash is offline
Old 26-07-2007, 06:19 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: urgent help needed!!!! computer gave some error messae while starting....
For dual chanel configuration where the throughput of ur ram theorotically equals that of the FSB of the processor*8.There are channels on ur mobo each channel should have equal amounts of memory for Dual channel configuration or the performance will not reach anywhere near theorotical.Dual channel config can only be reached with equal amounts of ram on each cahnnel.Check ur manual for channel info.
Harvik780 is offline
Old 26-07-2007, 07:08 PM   #3 (permalink)
tango_cash's Avatar
image of my mobo
http://img489.imageshack.us/my.php?i...15pcylgyd9.jpg
well there are 2 slots of blue color and 2 slots of black color.
what is the power connector thing about???
Old 26-07-2007, 10:40 PM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
The error popped up to notify u about the change in hardware.I do not have any idea about the power connector thing though.I m currently myself troubleshooting with my brother's high end config PSU problem.
Old 27-07-2007, 02:01 PM   #5 (permalink)
tango_cash's Avatar
what is this error for
GMail refuses to open in my Computer --- Urgent Help needed Tech&ME Software Q&A 10 06-01-2006 09:48 PM
computer not starting nevillle23 QnA (read only) 1 26-12-2005 07:17 PM
PC not starting ..Urgent Help needed! rkb2005 QnA (read only) 4 02-09-2005 11:14 PM
windows protection error . urgent help needed expertno.1 Software Q&A 2 24-05-2005 11:11 AM
CMOS Checksum Error. Urgent Help needed Yoda QnA (read only) 1 13-12-2004 09:44 AM
