Old 26-07-2007, 04:26 PM   #1 (permalink)
Smile Sys gets hanged
i have KOB 810 MB, P3 with 218 mb DDR ram and 40 gb WD HDD. my problem is that when i start my computer it gets hanged after 30 or 60 seconds and i have to do a cold reboot. is there any solution u frnds can give me?
Hellla if ya hea me!!!
yahfate is offline
Old 26-07-2007, 04:27 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Sys gets hanged
What OS are u running ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-07-2007, 06:41 PM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
First things:-
1)You have P 3 with 810 MB, 256 Mb SD Ram not DDR.It shows as 218 because your onboard video is sharing the ram.
You need to do this:-
Please clean the Processor fan and SMPS ( PSU ) by blowing air into it.Then go to bios and check if the current flow is stable from SMPS and stay in bios for about 20 mins .
The reasons is if the system is overheating or there is PSU problem then there will be system restart even when you are in the bios.
However is there is no system restart in the bios then you will have to check if you PC is infected with Virus or Torjon or worm.Run complete system scan.
Also do Check Disk on the harddrive if this doesnt do it..
Best of luck!
freshseasons is offline
Old 31-07-2007, 07:11 PM   #4 (permalink)
i stayed in BIOS for about 20 mins but no sys restart. i think there is virus prob but i had formatted my HDD several times but no avail. can u guide me how to remove tht virus....i think it is boot virus. thanks 4 ur prev tips.
Peace!!
yahfate is offline
hanged..... zany QnA (read only) 3 16-04-2007 04:46 PM
Should Bush be hanged? tanmoy_rajguru2005 Fight Club 53 12-02-2007 07:46 PM
Should Saddam Be Hanged? beatle555 Fight Club 29 06-01-2007 01:44 AM
hanged pc after logged in Tushar.bar Hardware Q&A 9 08-12-2006 02:42 AM
