okay, i have an Acer laptop with the following configuration:
- VIA K8T800
- Mobile AMD Athlon 64 3000+
- 512 Mb (2x256 Mb) RAM
- ATi Mobility Radeon 9700
i wanna upgrade to 2 Gb of RAM (2 x 1 Gb Modules).. wat i wanted to know is.. does my motherboard and processor support DDR2? if it doesn't which brand of DDR memory should i upgrade to, and wat will be the cost like? does my system support DDR 400??
Sayan Chaliha
If can do something or dream you can, begin it.
Boldness power and genius in it.
