Old 25-07-2007, 10:34 AM   #1 (permalink)
Default usb problem.
hai,
i have one strange problem in my usb.my usb is detect in the explorer panel.when i try to open it it wiill show
please insert a disk into drive.
please help me.
thecreativeboy is offline
Old 25-07-2007, 01:44 PM   #2 (permalink)
Try me
shantanu's Avatar
Default Re: usb problem.
can you make it a bit clear ... you meant that you have a pen drive and when you insert it in the USB port and click on the ICON in my computer,, it says the error... if this is it.. please post your USB drive make and your computer config. and which OS... ? if XP then try updating your USB drivers or just try to insert your drive in another comp. and format it.. !
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 25-07-2007, 04:26 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by thecreativeboy
hai,
please help me.
sounds like..ur USB drive has gone crupt.Please chk ur USB drive on another system...and post the result.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 25-07-2007, 07:21 PM   #4 (permalink)
Treatment in progress...
mukherjee's Avatar
Try two things:
1.Maybe ur usb drive has become corrupt.Try to format it with the software provided by manufacturer or even Windows can do it for u.
2.It might sound really silly-but u might try switching to another USB port.Well,it solved my problem one.
Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
PX100 II||Nikon D5100
Comments required : Balanced Armature Earphones
mukherjee is offline
Old 25-07-2007, 11:15 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by mukherjee
Try two things:
I dont think we can format any drive..when it is not detected by windows.
I may be wrong..plz correct me dear friends if I am.
TechTin.com
Old 26-07-2007, 12:07 AM   #6 (permalink)
mukherjee's Avatar
Actually, u see,he told the drive was being detected..so dats y i said dat.mayb i ws rong too.but,it worked for me.
Old 26-07-2007, 04:19 PM   #7 (permalink)
sorry for my late reply.because i have some project work.my usb is kingston.and the os is windows xp.when i click the drive it will show the error
please insert the disk into the drive.
and i also try it in another usb slot and also in another computer.but it diidnt works.please help me.
Old 26-07-2007, 05:47 PM   #8 (permalink)
1GB pendrive reduced to 120MB on its own plz help me seriously
See if that helps you in any way.
"Right Off the Assembly Line" --> Time to Seek & Destroy
abhra is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
