Old 24-07-2007, 04:29 PM   #1 (permalink)
Post pc taking long time to shut down
my pc is taking a considerably long time to save its setting and then to shut down .sometimes it becomes very irritating to wait for as long as 10-20 min.help me solve the problem.
mgupta is offline
Old 25-07-2007, 12:35 AM   #2 (permalink)
Yalam
Default Re: pc taking long time to shut down
If it really irritates u then do this:
go to
Control Panel / Power Options / Advanced (Tab) / Power Buttons
"When I Press the Power Button on my Computer:"
Select "Shutdown"
Now you can just press Power button on the front (likely) of your pc(for about 5 secs) and walk away while it shuts down properly.
or
press WinKey+R
type shutdown -s -t 00
press enter.
Yavin is offline
Old 25-07-2007, 12:54 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Paste following code in Notepad and save the file with name "vishal.reg" (including quotes):
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Control Panel\Desktop]
"AutoEndTasks"="1"
"HungAppTimeout"="1000"
"WaitToKillAppTimeout"="2000"
"LowLevelHooksTimeout"="1000"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control]
"WaitToKillServiceTimeout"="2000"
Now run the file and accept the confirmation. It should help u.
http://www.AskVG.com/
Vishal Gupta is offline
Old 25-07-2007, 09:46 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
start-->>run-->>type regedit and press enter
Navigate to:
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Set ClearPageFileAtShutdown value to 0
This should help.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 25-07-2007, 10:27 AM   #5 (permalink)
i also have the same solution that s given by the ravi.the lot of time to take shutdown because of the clear the pagefile.so
in the right side pane you will see the clearpage file at shutdown.and change the value to zero.
thecreativeboy is offline
taking lot of time to write dvd gau_pppu Software Q&A 2 05-04-2007 05:26 PM
taking time to shutdown deepakbm Hardware Q&A 6 02-10-2006 11:00 AM
dvd burning is taking extreme time 56561 Software Q&A 7 13-09-2006 07:25 PM
help me,,pc taking 10 min to shut down ? mkmkmk QnA (read only) 8 11-01-2006 11:11 AM
