Old 24-07-2007, 02:21 PM   #1 (permalink)
Default restarting computer!!!
a friend and i installed NFS-MW on his comp, and when we tried playin it the comp restarted. we tried re-installin but the prob persisted. the same happened when we tried playin fifa-07 and warcraft. we suspected a corrupt sector on the ram. (is tat correct??) and so we ran an app called memtest to check for the same but it said everythin was fine. wat could be the possible problems?
Phani
phanibhushan is offline
Old 24-07-2007, 03:30 PM   #2 (permalink)
Default Re: restarting computer!!!
scan it with av.
abhijangda is offline
Old 24-07-2007, 03:36 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
does it happen only while playing games or otherwise too?
two causes come to my mind:
1) driver issues
2) overheating
infra_red_dude is offline
Old 25-07-2007, 10:39 AM   #4 (permalink)
is any blue screen appears when the computer have restart.
thecreativeboy is offline
Old 25-07-2007, 12:03 PM   #5 (permalink)
King of my own Castle
freshseasons's Avatar
Gaming puts lot of stress on the PC components...And this is where they fail if there are some dents.
I dont think its virus ...!
I think its either Over heating or Lack of Good PSU Power.
First check the temperature of CPU and GPU card if you have it .
Then try exchanging the SMPS from that of your friends with a higher rates ones.
freshseasons is offline
Old 26-07-2007, 11:54 AM   #6 (permalink)
Its doesnt seem to be a virus issue coz i checked it.
as of over heatin, i kinda ruled tat out coz i use zone alarm and according to its log the temp is below 50 deg. so i think its fine.
no blue screen appears when it restarts.
it happens only during gaming, i once ran the comp at 100%CPU usage for bout a min and a half and it din restart.
thanx for all ur posts!! problem still persists.....
cheers
Phani
Old 26-07-2007, 02:30 PM   #7 (permalink)
Wire muncher!
you use zonealarm to check ur temps?!!!
Computer Restarting again and again.... Manshahia Hardware Q&A 6 04-06-2007 07:26 PM
Computer Restarting....Randomly..Plz help shyamno Hardware Q&A 9 16-04-2007 11:50 AM
Help...Computer is restarting while installing Windows XP... debaisaindian Hardware Q&A 11 11-02-2007 09:54 PM
Computer restarting...:( nilesh4u QnA (read only) 13 30-03-2006 11:44 PM
computer restarting automatically dittualex QnA (read only) 1 14-11-2005 12:44 PM
