Old 24-07-2007, 10:26 PM   #1 (permalink)
Default Gmax mouse not recognizined
I have a compaq presario V6000, windows vista basic loaded. I bought a gmax optical minimouse.. and it cant be recognized.. by it..and it dosent work though i see the light on. I didnt get any drivers with the mouse.
Please help me.
help me please... maybe its a problem in vista compatibility.
chillnow is offline
Old 25-07-2007, 01:56 PM   #2 (permalink)
Try me
shantanu's Avatar
Default Re: Gmax mouse not recognizined
i think you need to change the USB port (i mean just unplug the mouse and use another port) and if you have try another mouse ps2 or usb.. then restart you PC and at boot time insert the USB mouse(gMAX) in the port.. it should show your mouse ... if not then check the mouse in another pc.. if it works then tell it here...
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 27-02-2008, 01:53 PM   #3 (permalink)
Smile Re: Gmax mouse not recognizined
hey ...i hav been stuck up wid d same problem..!
usb not recognised is wot i see, n wen i check for drivers online...it sayz d windows hav d right drivers installed..!! so hard luck...
n yes i do hav tried d rebooting n replugging thing....!!
so nething else u can help with???
ne help appreciated....
sk_9873 is offline
Wow! What a Mouse marulez Technology News 2 28-05-2007 09:33 PM
best mouse gdatuk QnA (read only) 3 22-09-2005 04:46 PM
Wheel mouse optical and Basic optical mouse!!! raj_4588 Peripherals 5 05-08-2005 07:14 PM
MaD MoUsE ranjithbajpe Peripherals 1 14-05-2005 11:01 AM
Mouse Problem- Psyco Mouse!! khattam_ Peripherals 2 16-02-2005 06:54 AM
