Well What About Need For Speed underground 2? and Carbon?
will Battlefield 2 Run Though i already own it
NFS UnderGround 2 will run smooth without enhanced contrast on.Yes battlefield 2 will run but u will have choppy frame rates with the X1300.Also you should have at least 1 GB ram to run Battlefield without hiccups.If u want to play resource hungry games u should not consider cost factor.U should satisfy yourself by buying a good mid range GPU.
Is the X1300 256mb 128bit gfx card good compared to my curent 9250 128mb 64bit card?
ohh and i have a 9250 128mb 64bit and i am Getting a x1300 256mb 128bit and i can run mw at 640x480 x2 aa and all details on
so will it run better on a x1300 256mb 128bit
