Old 23-07-2007, 05:28 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Unhappy Faded Monitor!!!
Hi techies..
I own a HCL HCM582 Monitor..The problem is..the colors are not bright as normal..they look faded..very dull..as well as thr is no brightness..i tried adjusting the settings..no go..BTW its a CRT monitor.
Wat's the problem??
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 25-07-2007, 01:51 PM   #2 (permalink)
shantanu's Avatar
Default Re: Faded Monitor!!!
did you tried Degauss.... or reset.. i had that monitor a long time back... it got over in ONE year , if the degauss works then its ok.. otherwise try folding the cas=ble the monitor input cable.. many times the cable gets bad from some ends.. so folding it does the job.. try this..
shantanu is offline
Can we use TV as monitor ? ruturaj3 Hardware Q&A 4 03-04-2007 05:02 PM
Monitor vineetrocks2005 Hardware Q&A 1 12-11-2006 07:41 AM
can i use tv instead of monitor. kuldeep bhardwaj QnA (read only) 5 27-02-2006 07:39 PM
What about monitor , LAN....? zeus_zz Hardware Q&A 8 04-11-2005 01:50 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
- by kool
