I own a Intel D845GVAD2 mobo..I have 2 USB slots in the rear..like to add another 2 in the front..checked my manual and got confirmed tht i can add front panel usb slots too.
My query is how can i do tht, wat all things i need to buy..can we do it ourselves.
Pls help me out.
NOTE - Even my case as a opening in the front for USB.
the port costs between Rs. 50 to 100. If it consists of audio ports too then the cost may be upto 150. nothing more.
on the pins it is mentioned +5v, earth, etc etc. check your motherboard manual and connect accordingly.
If the usb port doesn't fit in to your front panel, use fevi-quick.
__________________ Simplicity is the ultimate Sophistication HP dv6 6121tx: Core i7 2630 QM | 4GB | AMD 6770M 2GB GDDR5 | 640 GB
Nokia N86 8MP
Guys I am in real need of the USB slot in the front..since the USB gadgets I use is more now..
What should I ask for the USB slot in the shop..I askd my frnd to enquire and he enquired in Mercy electronics in chennai and the guy in the shop had told it wil cost 350 bucks...
