23-07-2007, 11:15 AM
Tribal Boy
19 inch widescreen LCD. How to set resolution ?
[Edit]Solved it, Please see my post below ...[/Edit]
I am having problem with my 19 inch widescreen LCD. I know the correct resolution should be 1440*900. But I can't see it in the list, any suggestions ? At present it looks like kinda stretched (1280*1024). This one is Viewsonic VA1903wm and I am on Win XP.
23-07-2007, 11:57 AM
Learner
Re: 19 inch widescreen LCD. How to set resolution ?
dude.... what's ur graphics card. or integrated graphics, which one?
there's a few tools to force resolutions, but it depends on what gfx u are using.
23-07-2007, 12:03 PM
* Teh Flirt King *
Whats the Graphics Card? I think there is a tool for Nvidia Gfx cards to force resolution.
23-07-2007, 12:13 PM
Tribal Boy
OK, mine is integrated, no seperate graphics card. Is that a problem for widescreen type resolutions ? Motherboard is Asrock K7VM4. Shared memory 64 MB.
23-07-2007, 12:51 PM
Laptoping
The problem is, VIA UniChrome is very old. Support for wide-screen may or may not be there. You should upgrade to the latest drivers and check it out. You can always use Powerstrip to force resolution.
Before getting the LCD, you should've checked out if there is support for widescreen or not. I believe driver update should fix the problem. Don't forget to enable ClearType too.
23-07-2007, 04:13 PM
Learner
well the thing is powerstrip does not always work, though in his case it should I guess.
23-07-2007, 05:07 PM
Tribal Boy
OK, it seems powerstrip is not working .. I will try again though.
Buying a graphics card will solve this ?
23-07-2007, 08:38 PM
Learner
sure it will
23-07-2007, 10:43 PM
If the system is old then buying a graphic card (pci/agp card) will still not solve that, as not many pci cards support wide screen, few agp card will do but wont have dvi port to run this wide screen.
There are so many LCD discussion here you should have read it before buying.
My friend 2 days ago bought the wide screen & he too got stuck & cant do anything about this now except changing the comp. The dealers in india do not tell this fact that these screens are not going to work optimally on older systems & the image will remain stretched.
24-07-2007, 08:41 AM
yes it is the old onboard GFX chip that's causing the problem..
works fine with nVidia 6150 onboard chip though.
Buy a decent AGP card..
24-07-2007, 10:41 AM
Tribal Boy
OK, just called the dealer from whom I bought the Pro/ Motherboard. He said the AGP card will solve it. 1500 or so. Hope that will solve this issue. Will try it and will post details.
24-07-2007, 01:37 PM
1500/- card wont have the dvi port which is required to get the best performance from these wide screen.
If he can replace (provided you want it) the wide screen with a regular 19 inch that will be better for you without buying the card.
My friend is now trying it for a replacement.
24-07-2007, 05:28 PM
Tribal Boy
OK, solved it. Pretty happy
The card is NVIDIA GeForce FX5200.
I am not sure whether this is a good card, but it worked for me
After installing it automatically set resolution to 1440 x 900 which is perfect for my widescreen LCD
Thanks a lot for your suggestions friends, that really helped.
Meantime, the price is Rs.1508
24-07-2007, 06:51 PM
thats a good agp card supporting widescreen & the only option I found for my friend too, but does not have the dvi port.
Just for info to all others, all nvidia cards support custom resolution & widescreen.
24-07-2007, 08:38 PM
Tribal Boy
Thank you, so it is not a bad card ? Great
dvi port - thats for connecting TV etc rt ? Not worried on that as I use this in my office and only for work.
24-07-2007, 08:52 PM
DVI is digital video interface & its used for connecting monitor with it not the TV. Its better than the analog signal & gives clearer & better color.
24-07-2007, 09:28 PM
Tribal Boy
OH, sorry, didn't know that. Thanks for the info.
Anyway pretty happy with the present resolution and working of LCD. so no worries
24-07-2007, 10:08 PM
Turn The Page
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
welcome to the Nvidia GeForce FX5200 CLUB
This Space Has Been "RESERVED" !!!
25-07-2007, 01:48 AM
#19 (permalink)
Core i7 (nehalem) Owner
It certainly is not bad card dude, but jus old, I too had this card long back (7-8 months back) then upgraded to Nvidia GE Force 7600 GS (I too hv a Samsung LCD 19" Monitor).
Ur FX 5200is perfect for ur needs...  so dnt worry and jus be happy to do ur work
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
