23-07-2007, 10:11 AM
The Frozen Nova
Blowing Dust Out
Is it ok to blow dust out from your CPU by using a hair dryer or blower?
www.nerdweed.blogspot.com
23-07-2007, 10:27 AM
UbuntuUser
Re: Blowing Dust Out
Yes and you can also use vacuum cleaner in reverse mode.
23-07-2007, 10:28 AM
GUNNING DOWN TEAMS
u can use air blower.....but avoid hair dryer...as it will heat up CPU and adjoining components.....
The Frozen Nova
Don't have a vaccum cleaner, so trying to be efficient with what I have.
How much will an air blower cost me.
23-07-2007, 10:29 AM
UbuntuUser
^^ Heat will go away. Its wont stay there forever
23-07-2007, 10:32 AM
GUNNING DOWN TEAMS
^^^^ try using .....mobo will also go for ever and u will get new one
23-07-2007, 10:39 AM
No pain....No gain
Don't use hair dryer instead use a can of compressed air. It comes with a thin and long nozzle attachment (good for tight spot)  .
23-07-2007, 10:57 AM
The No.1 Stupid
^^how much it cost ?
n00b forever...
23-07-2007, 01:09 PM
King of my own Castle
I think get a simple blower from Hardware store. It will cost you 800 Rs but it will last you for years and effectively this is the best thing.
23-07-2007, 01:41 PM
The Frozen Nova
Thanks for your suggestions. I will get a blower soon.
23-07-2007, 04:23 PM
Cool as a CUCUMBAR ! ! !
dont EVER use vacuum cleaner ........ it creates heat & moisture 2 ......
ur hardware guy will always tell u 2 maximize ur expenses ........
use a air pump or blower ........ it costs u mere 45-80rs ........ 2 cheap na .....
... W H O T ...
24-07-2007, 12:31 PM
The Frozen Nova
Yeah cheap but do we have to pump it or it requires electricity.
24-07-2007, 01:23 PM
its a simple pump ........ just like the rubber bulb of blood pressure meter ......
just squeeze it & it blows air through a small tube .........
... W H O T ...
24-07-2007, 02:00 PM
Yeah.Air pump is cheap & effective.
24-07-2007, 03:25 PM
The Frozen Nova
@ax3,
That thing doesn't blow of dust completely and is very painful. I boought it for 20 bucks from Lamington Road.
So anything that runs on power will be better.
How much does a can of compressed air cost?
