Old 20-07-2007, 10:55 PM   #1 (permalink)
Default please help me with hdd problem
i am trying to upgrade my PC and bought a Seagate Barracuda 320 Gb SATA drive. now the problem is that my old drive is a Seagate IDE drive (80 Gb). i would like to keep it as a secondary drive and the barracuda as the primary one. i have a Asus 5ld2-vm mobo.
i am really confused how to go about it and the mobo bios settings.
can anyone lease help a total novice in this?
thanks in advance.
p_roy is offline
Old 20-07-2007, 11:02 PM   #2 (permalink)
slugger's Avatar
Default Re: please help me with hdd problem
use d jumper setting 2 make d SATA ur primary master and d 80 GB 1 d slave
d jumpers pins r like d pins not unlike d pins of d IDE connector but only 6 in no dey r placed right next to e data cable slot
d jumper is a small teeny weeny cap like thingy dat is used 2 establsih contact between 2 jumper pins
d img shud give u a fair idea of wat 2 look 4 wen looking 4 a jumper
d actual thingy might wary a little
slugger is offline
Old 20-07-2007, 11:25 PM   #3 (permalink)
thanks you so much for your reply.
p_roy is offline
Old 20-07-2007, 11:43 PM   #4 (permalink)
slugger's Avatar
keep us posted on ur HDD adventure
slugger is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by kool
