But sometimes due to some software or hardware installation it does switches to PIO. No harm in checking it and ensuring it frm that point.
Anywayz also try changing ur media to see if it helps.
My friend's Sony used to write on a writex -R at full speed in some 25 mins but on the Sony media it wrote in 8 mins flat !
its the dma to pio mode fallback feature of windows .all you need to do is check out my tutorial on it. change pio transfer mode to UDMA
it will help you 100% sure only if you can follow the procedure correctly
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
