Old 20-07-2007, 11:24 AM   #1 (permalink)
Default Wireless AP or Router
i have a query.
i live in a colony which has shared a broadband line to all flats via LAN..
i now have a desktop pc and a wifi-enabled laptop...
wat do i need so that i can connect to the net over wifi,, an ACCESS Point or a Router..
i need such a device dat my pc and my laptop can communicate to each other and share the net connection simultaneously... yet being invisible on the "colony LAN"...
Winston is offline
Old 20-07-2007, 04:24 PM   #2 (permalink)
Default Re: Wireless AP or Router
you will need a router then. netgear WGR 614 would suffice.
kooabs03 is offline
Old 22-07-2007, 09:44 AM   #3 (permalink)
Ganeshkumar's Avatar
Yes Go for Wireles Router!! I am using Trendnet...Dont know whether available in India....
U pls update the price if u have asked any dealer....
Ganeshkumar is offline
Looking for Wireless Router Ganeshkumar Hardware Q&A 7 12-06-2007 04:55 PM
Wireless router jobin Networking 1 15-05-2007 01:56 AM
trouble with wireless router hooky Software Q&A 4 12-12-2006 06:00 AM
Looking at this wireless router? comments rohanbee Hardware Q&A 2 17-11-2006 09:11 PM
wireless router help hemant_mathur Hardware Q&A 1 01-05-2006 12:19 AM
- by kool
