Old 20-07-2007, 01:00 AM   #1 (permalink)
joy.das.jd
Posts: n/a
Default Problem reading DVDs written by SONY AW-G170A
I am having a problem with SONY DRU AW-170A drive. I bought this drive about a month ago and it was working fine. But then suddenly one day it stopped reading DATA dvds that were created by this drive. CDs and data dvds work fine. Digit dvd also work fine.But some of the data DVD and all the dvds from it appear blank after the writing process is finished. Nero says Burning sucessful. I have tried burning them at very low speed [2X] but still nothing happens. However i am able to see and extract the files using ISOBUSTER. SO pls pls help me out.
I generally use POWERISO to burn dvds as I have problem writing dvds with NERO [both 6.X.X.X and 7.X.X.X both OEM versions and retail demo]
I read a few review here and found that this drive is a real sick drive. I have already tried to update the firmware but it is not listed on the sony's site. So my questions are
1.) Should i get the drive replaced? If so then which are the brands i should look for? If possible then pls also mention the model.
2.)Which is a good dvd writing software? Should i use nero or is there any other better alternative to it?
Old 20-07-2007, 01:04 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Problem reading DVDs written by SONY AW-G170A
nero 7.x gives problems even for me plus its a big bloat. i was using nero 6.6 but now i've moved over to vista so even i'm in need for a good cd burning software.
try cdburnerxp, deepburner etc. tho they lack advanced features they are pretty much usable. u can only judge these kindsa software when u use them once.
infra_red_dude is offline
Old 23-07-2007, 12:34 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
contact hardware vendor from whom u got it .........
or contact sony support here ........
or check this drive @ frds place with dvd`s burnt ........
Nero 6.xxx r good ....... error free .........
... W H O T ...
ax3 is offline
Old 23-07-2007, 05:40 PM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
I have the exact same DVD drive and i have faced no problems what so ever after using it for 2 months.It seems u have harshly used the dvd drive anyways i also overclocked my GPU and got it replaced so u can also get it replaced.i suggest u should buy SONY drives directly from dealers.
Harvik780 is offline
Old 26-04-2008, 09:41 PM   #5 (permalink)
Same problem here!!!
Can't read DVDs.
vvvaishakh is offline
Old 26-04-2008, 11:14 PM   #6 (permalink)
joy.das.jd
Posts: n/a
Ok a Reply to a topic so old...
Anyways i got the drive replaced for SONY DRU-G190A and thats a cool drive. Did not have any problem with the drive what so ever and i burn almost 20 DVDs every week (Dont ask what i burn on them). And by the way i use DiscJuggler to write dvds and its a kewl software...
My advise to vvvaishakh get the drive replaced as soon as possible
DVD Drive not reading CD DVDs.. plz help.. medigit Hardware Q&A 2 18-03-2007 02:46 PM
HELP: SONY DVD RW DW-G120A is not supporting MoserBaer DVDs! Vishal Gupta Hardware Q&A 35 19-04-2006 01:27 AM
dvd drive not reading all dvds gauravcreations Hardware Q&A 2 06-12-2005 11:38 PM
Samsung DVD Rom not reading any DVDs saint QnA (read only) 11 07-03-2005 03:15 PM
Problem Reading Files In SONY CDRW dragonball QnA (read only) 6 22-10-2004 05:07 PM
- by kool
