Originally Posted by speedyguy
@Kniwor: dude, m not talkin abt a vga to svideo cable but itsa rca to svideo which contains one rca connector(looks like ps2 pin) plugged into laptop which sends both audio n video reception...(ps: not plugging to vga port)....n other end has a video(yelllow) and audio-steriophonic(white n red) plugs...totalling 3 for both.....
so i dun think i need 2 plug streriophonic audio jacks seperately unless i use vga port for my tv display...
@freshseasons: hi is this vipin? if yes hope u rem we met in ngp may b long time back....hws lyf?
Enjoy~!
lol..
Ok dude, firstly u 'are' talking about S-Video to RCA Composite.
This is an S-Video port, in ur laptop... that u are using...
and the yellow video cable u are talking about it RCA Composite, u probably have something like this
In this case, the S-Video ONLY carries video dude, the VGA is nowhere in the scene, I've my PC connected to my television, and works great. This will NOT work, you will need to separately connect the audio out of ur lappy to ur TV. And I would also suggest u to use the S-Video input in ur TV if there is one, instead of RCA composite, If there's no S-video, use the RGB component input, get an S-Video to RGB cable, the RCA composite will have a low quality.
