19-07-2007, 01:15 AM
Rebooting
ThermalRight Ultra 120 eXtreme
+ Panflow 120mm Ultra High speed
Product URL => http://www.thermalright.com/a_page/m...20_extreme.htm
Bought from => http://www.sidewindercomputers.com/thulex.html
Got the Product today morning, wasted half the day behind it testing....
1st look, Packaging was good, made to suntained the Indian Post office rough handling...
Installation
Installing the Heat Sink on Motherboard was pretty straight forward and quite easy !!! but the a pipe of the heat sink is touching the motherboard birdge cooler heat sink !!!
If u can see in the image (Sorry Digi Cam not available now so only option now is 1.3MP Mobile CAM) the Pipe is touching the heat sink of bridge cooler !!!
But had tough time with few other things, Like I find it hard and confusing on Installing those 2 slim (Damn slim) rubber bands which are there fore anti vibration !!!
I also attaching the Fan with heat sink wasnt easy too... as u have to manage to attach the fan with simple 2 metal string !! so srew or such set up..... !!!
I had trouble fitting the mobo in to the cabbi also, as wight is a foctor so hard to handle the Mobo, freely as one can do with Intel Stock cooler installed !!!
Over all installation, I would give 2/5 ... not quite satisfied... but as u no, its a pro level product, one is expected to take that challange... !!!
Noise
though It says ultra High speed fan, but not that noisy at all !!!
Performance
So here comes the Main reason !!!
Hardware
E6600
P5N-E SLi
2 GB DDR-II 667MHz Transcend (I have 4 but as OCing high so removed 2, If incase)
XFX 6200 LE
2 x 250 GB SATA-II
80 GB SATA-I
80 GB PATA
DVD RW
DVD ROM
Floppy Drive
ColorSit 450 Watts
Software
Windows XP Pro SP2 uptodate
Originally Posted by Set 1
CoreTemp
CPU-Z
PC Wizered
ASUS Probe
Originally Posted by Set 2
Pi Calculator
2 Processes, 1 on each core
Originally Posted by Set 3
AutoGK
Nero Recode
NFS Most Wanted
How did I run Basic Tests ??
Set 1 for Temp and other settinsg monitoring...
Set 2 for Stability test on OC !!
Set 3 for Multi Tasking
Start with Stock (FSB @ 1066 / Rest Auto)
OC (FSB @ 1175 ... Procy @ 2.64 ... RAM @ 667 .. vcore @ 1.28 .. Rest @ Auto)
the Temps are 39c idle, on load 41/42c... System is running fine, All tests pass...
OC (FSB @ 1250 ... Procy @ 2.89 ... RAM @ 667 .. vcore @ 1.28 .. Rest @ Auto)
the Temps are 39c idle, on load 42/43c... System is running fine, All tests passed with ease...
OC (FSB @ 1500 ... Procy @ 3.4 ... RAM @ 750 .. vcore @ 1.32 .. Rest @ Auto)
OS booted up but failed the Pi Test, Hardware error, system halted !!! 1st i was tring with vcore 1.3, increased to 1.32 still same, so, Removed 2GB RAM, removed One 250GB and 80 GB SATA1 HDD.... still the same, but this time Pi is going to half way, then System becomes Non responsive...
So went little Back to this, with, 2 GB DDR-II and one 250GB with one 80GB HDD
OC (FSB @ 1450 ... Procy @ 3.29 ... RAM @ 667 .. vcore @ 1.32 .. Rest @ Auto .. Removed Hardware)
the Temps are 39c/40c idle, on load 44/45c... System is running fine, All tests passed with ease...
Idle
Load with Pi Test
Conclution
My hardware Didnt allow me to go higher than 3.29 GHz, there can be few reasons, but I suspect most obbious is the SMPS of 450 Watts !!! but also can be few more, like RAMs, or simply P5N-E SLi cant go beyond FSB 1500 ?? So wasnt able to give my proper thought in it, as now Running at 3.2GHz...
Will I recomend this to any one ??
Well to say this i need to compare few things on hand, which I cant, I only have Intel Stock Cooler and this one... as u can see either my Temp readings are wrong or Cooler at till 3.2 GHz keeps the temp same compare to the Stock Speed of 2.4 GHz, unless I can take it to a point where I cant go further because of heating issue, till then hard to comment...
But certainly if those Temp readings are right, in any case till 3.2 GHz i reached with my hardware, temps readding are same !!!
Any performace boost while overclocking ??
At multi Tasking no... with Stock 2.4 GHz AutoGK used to encode 4.1 GB VOB to 700MB xvid at around 45 to 55 mins, while I am running Nero to Recode one DVD to 1 CD, and playing NFS... result is more or less same even at 3.2GHz !!!!
Only noticible Diffrence is with Pi calculation (2M) between Stock 2.4GHz to OC 3.2 GHz !!!
Right now Little short in cash, so have to wait a little for that PSU !!!
rebooting
ChotoCheeta.com
19-07-2007, 02:41 AM
No pain....No gain
Re: ThermalRight Ultra 120 eXtreme
Yup, the PSU is holding you back. I would suggest that you keep the RAM at its default values and just o'c your CPU. Get the max stable o'clock then do the same with your memory. When you reach the max for memory try to tighten the timings.
Basically just try to balance the whole overclock.
But good review..........installation of these cooler does takes some effort.
BTW, the package did include some thermal paste?
19-07-2007, 03:03 AM
Rebooting
yeah, to my surpise the ThermalRight package inlcuded a lot of Thermal Pasting i just used 20 may be 25 % of it on CPU and on the back of the cooler, but still 80 % left
anyway, I didnt ordered the Thermal Paste  it came by its own
Thnx for the comment !!
rebooting
ChotoCheeta.com
19-07-2007, 03:54 AM
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
^^great review Saurav
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
19-07-2007, 04:05 AM
The No.1 Stupid
Really Great Review yaar ... great effort.
n00b forever...
19-07-2007, 07:06 AM
BW Waster Certified
Location: Latitude: 22°38'30.96"N, Longitude: 88°25'52.26"E
That's a really great review from a user prespective..hope we some more form others also...
P4 1.70 GHz | Asus P4P800-VM | 1.5GB Transcend DDR-400| XFX 6600GT 256MB GDDR3 AGP | Seagate 320GB SATA 3Gb/s | Asus DVD Writer | CoolerMaster eXtreme Power 600W
19-07-2007, 08:08 AM
Rebooting
thnx for the comments !!! john_the_ultimate got another solid Cooler  , lets hope we get another review of that from him too
By the way, 600 or 650 Watts PSU in Kolkata.... Give me some idea !!!
rebooting
ChotoCheeta.com
19-07-2007, 09:20 AM
A word about the position of the fan...It should be on the other side of the cooler, i.e. it should blow air across the cooler fins and out the back of the cabinet...The push configuration is more effective than the pull configuration.
Good review though, and yeah even I was impressed with the amount of thermal paste TR included in the package.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
19-07-2007, 12:05 PM
No pain....No gain
Saurav you can get Coolermaster eXtreme Power 600W for around 3-3.2K (don't know the current price). And yes put the fan on the other side as Hells_Fury has suggested. Also install the rear exhaust fan, will help in cooling.
As for my review, first let me do some more test, haven't got enough time. Will post later.
19-07-2007, 12:07 PM
Rebooting
Originally Posted by Hells_Fury
A word about the position of the fan...It should be on the other side of the cooler, i.e. it should blow air across the cooler fins and out the back of the cabinet...A word about the position of the fan...It should be on the other side of the cooler, i.e. it should blow air across the cooler fins and out the back of the cabinet...
Take a Look at this pic....
As u see there is a 240v 120mm FAN right on top of the other side pulling Air Out !!! Wont that be enough ??
Thanks !!!
Now put some light on 600 Watts or 650 Watts PSU, affordable PSU, those 7k PSU are really not affordable for me
rebooting
ChotoCheeta.com
19-07-2007, 12:31 PM
It would be better to use the side panel fan as intake and to install a rear exhaust fan. That would setup better airflow in your cabinet. An additional front intake fan would be ideal...
Regarding the PSU's, sorry cant help you. I dont really know much about them.
19-07-2007, 12:35 PM
Rebooting
OK challo got some advice !!! will look for that in Local Kolkata Market when having some cash in hand !!
No problem... thanx for the input regarding air flow though !!!
Tell me guyss, these 120mm fans doesnt cost that much... in some review Sites, they show putting 2 fans on both side of the Heat Sink !!!
??? how about that ??
rebooting
ChotoCheeta.com
19-07-2007, 12:41 PM
there s stock of Coolermaster 600 Watt in Kolkata.
check out Velocity Computers.Mobile-9331858297.
bt the price will be a bit more than 3.2K
DOTA is really addictive :D
19-07-2007, 12:43 PM
Rebooting
thanks ... will check that out !!
rebooting
ChotoCheeta.com
19-07-2007, 01:30 PM
Doesnt really help that much. You can do it if you really want to but you wont find too much difference in temps. Also, mounting brackets and rubber strips are provided only for a single fan. You will have to find some other means to attach the second fan (Ive seen review articles using rubber bands  )
21-07-2007, 04:08 PM
Rebooting
OK... Cooler Master 600 Wattrs Model is therefor Rs. 3500 !!! Let me arrange some money to get one !!!
even I found Attaching the Default Fan a headahe  so till now I would stay away from thinking of 2nd fan...
but is there any way to get Those Metal Strings and Rubber Strips came with the box at local market ??
rebooting
ChotoCheeta.com
21-07-2007, 04:15 PM
Microsoft MVP
Nice Review buddy.
21-07-2007, 04:18 PM
Dont think so...But I think I saw the fan clamps selling separately at sidewinder. Not too sure about that.
Edit - Here you go: http://www.sidewindercomputers.com/thflfanwiclf.html
21-07-2007, 06:08 PM
#19 (permalink)
No pain....No gain
Saurav, just install a rear fan that would act as the second fan throwing the hot air out of the cabby. But do move the persent fan to the other side of the cooler. Try this method if not satisfied, you can aslways get the extra clips from the link Hells_Fury had given.
21-07-2007, 07:48 PM
#20 (permalink)
Rebooting
Will open the cabbi for Changes once I get the new SMPS...
there is a problem... See from the pict, TR Ulta left very little room between it self a the present SMPS... I am afraid may be the Cooler Master 600 Watts wont fit in along side of the TR Ultra
Shiping charges are really high  but thank you for the URL... atleast will be handy when needed
@Vishal
Thanks for the comment !!!
rebooting
ChotoCheeta.com
21-07-2007, 09:18 PM
#21 (permalink)
I WANT MORE FPS!!
What about the noise?
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
21-07-2007, 09:54 PM
#22 (permalink)
Rebooting
My home is Situated right on the main road, also I already have one 120mm 240v External Noisy Cabii fau running so i dont feel any thing at day time, but at Middle of the night, turning the room Ceiling FAN and the CAbi Ext 120mm 240v fan off, then only i can hear its sound !!!
Tell u what , in our cafe we have couple of Celeron D 2.4 GHz Procy (LGA 775), I feel their Stock coolers are loader than my ThermalRight Ultra 120 eXtreme
rebooting
ChotoCheeta.com
22-07-2007, 02:43 AM
#23 (permalink)
No pain....No gain
Yes those panaflo fans are really silent. BTW, what's the rpm? And don't worry about space the coolermaster will fit fine. Only concern seem that the fans would touch the memory modules.
22-07-2007, 12:06 PM
#24 (permalink)
Holy cosmos so finally u got the cooler...Bengali Lingo:Ekhon Saurav thanda...haha
Ok I had a query...the fan mounted on the side of the chassis (wall) facing the cpu cooler does that pull in air or does it pull out air of the chassis...seems like I'm confused
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
22-07-2007, 12:08 PM
#25 (permalink)
Rebooting
Its pushing the Air in to the heat sink, but as per suggestion next time when I open the cabi for SMPS change I would put it in other side of the heat sink
rebooting
ChotoCheeta.com
22-07-2007, 12:16 PM
#26 (permalink)
Congrats on the TR120E. Mount the fan on the other side. NV 650i SLI allows Unlinked mode, make full use of it
Not sure but i heard that boards Vdroops like anything so bump Vcore to get stability. Also 3.2 is peanuts for that cooler and the CPU too.
I am just praying you dont have one of those doomed E6600
Best Of luck man !
22-07-2007, 02:58 PM
#27 (permalink)
Rebooting
Well me to thing that is one possiblity, how ever, untill i get the 600 watts SMPS its hard to say !!!
as over 3.2 GHz with that unstable OC, system boots, but fails the load test, what does that symtom suggest ??
@darklord,
Need some advice,...
As I was going through Johns OC settings, one thing I noticed that at higher value to E4300 he needed to bump up the RAM Voltage !!!
So, this is what I did, I riped up 2 GB RAM, and 80 and 250 HDD, (SMPS Cant take the load)
FSB @ 1500 , vcore to 1.34 , RAM Voltage 2.083 (from default auto and one stepup from 2.013) RAM FSB @ 667 (Default)....
now run the Pi Test, yet to do the extensive ripping and Multi Tasking tests !!!
But before that, Tell me guys, with Transcend Jet RAM 667 MHz, what could be my safe voltage limit ??
rebooting
ChotoCheeta.com
Reason: Automerged Doublepost
22-07-2007, 03:40 PM
#28 (permalink)
Sorry but what exactly is your question for me ?
If you are asking about default VDIMM then its 1.8V as per JEDEC standards, For value RAM, its ok to bump upto 2.1V not more than that.What chips are there on the RAM module also matters in determining VDIMM and so does what PCB is used. normally RAM makers use 6 layer PCB but some High Performance RAM makers use 8 layer PCB in their Premium Kits which can handle High voltage much better
22-07-2007, 04:17 PM
#29 (permalink)
Rebooting
For 3.4 GHz or above what should I set the vCore ?? more 1.36 seems OK ?? or Should I push it up to 1.4v ??
As at 1.34 vCore passed the pi test but good restarted on multi tasking test with Blue Screen Hardware failor error
And Boy the Cooler is certainly doing its job, as at 3.4 GHz on load at Pi Test 47c max on both core !!!
rebooting
ChotoCheeta.com
22-07-2007, 05:45 PM
#30 (permalink)
Push some more volts man. You dont have a X6800 for sure which is a cherry picked core which will do insane clocks at low voltage
dont worry, push some juice into it
