18-07-2007, 10:37 PM
Techie By Heart
Assembling My Own Rig
█§ ║╖ î v â ╥╥╖█(™©)
20-07-2007, 01:00 AM
Techie By Heart
Re: Assembling My Own Rig
y ain't i gettin any replies here??????????
20-07-2007, 02:10 AM
GaurishSharma.com
20-07-2007, 12:01 PM
Hey dude look at my config. i bought last saturday.
AMD Athlon 64 X2 5200+
and
ASUS M2NPV-VM : 12900
Kingston 512MB X 2 DDR2 : 1100 X 2
Segate 250 GB : 2900
Zebronics Peace : 2500
Liteon All writer with LightScribe : 2100
Altec ATP3 : 2700
these are cost estimated by shopkeeper ; but actually when buying they chrage 100-300 rs less on each product.
20-07-2007, 07:41 PM
Google Bot
Asus M2A vm..
amd athlon x2 5200+
Transcend 1 gb ddr2 667mhz ram.
Seagate sata 2 250gb
03-08-2007, 10:57 PM
Techie By Heart
which case is better? Or is there any other which is better than these? & does the the Zebronics case have PSU???
* iBall Gamer (with 400W PSU) - Rs.1,750/-
OR
* Zebronics Antibiotic - Rs 2000
OR
* Zebronics Peace
03-08-2007, 11:19 PM
amd x2 5000+ 5.1k and amd M2NPV NM @ 4.2k !!!
RAM and other stuff u choose
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
03-08-2007, 11:35 PM
Techie By Heart
here r some of parts i've thought of :-
RAM ->
Transcend JetRam 1GB PC2-5300 -
Size: 1GB DDR2 667MHz
Latency: 5-5-5-18 (CAS,tRCD,tRP,tRAS)
Function: Unbuffered
Operating Voltage: 1.8v
Warranty: Lifetime
Rs.1,950/-
HDD ->
Western Digital Caviar SE16 WD2500KS 250GB -
Specs: 250GB, 7,200rpm, 16MB Buffer, SATA 300MBps Interface
Rs.3,200/-
Processor ->
AMD Athlon64 X2 5000+
Specs:2.6GHz, 1MB L2 Cache, 1GHz FSB, 90nm, Enhanced 3D Now!, NXBit, AMD64, Cool’n'Quiet
Price: Rs. 6,000/-
OR
AMD Athlon64 X2 5600+
Specs:2.8GHz, 2MB L2 Cache, TDP -89W, 1GHz FSB, 90nm, Enhanced 3D Now!, NXBit, AMD64, Cool’n'Quiet
Price: Rs.7,500/-
Help me out with the mobo & is there anything 2 change in the above config????
04-08-2007, 12:34 AM
^^ from where have u got those stupid prices ??
here goes AMD X2 5000+ dont exceed 5300 Rs.........i got this for 5100 rs
ASUS M2NPV NM with HDTV Out for 4200 Rs
and transced 1 GB 800 Mhz RAM for 2100 Rs
while i was offered 1 GB 667 mhz transcend for 1600 Rs.....both 3 yrs warranty...i dont know from u got lifetime warranty !! common for RAM ??
for AMD X2 5600 the price shld be around 6800 Rs dont pay 7.5k !!!
04-08-2007, 01:03 AM
Techie By Heart
saw the price at a site. anyway should i go for 5000+ or for 5600+ as there is 0.2GHz & the cache difference & also the power consumption. & thanx for the reply.
04-08-2007, 01:13 AM
naa since its a budget 1 5000 will just do fine !! later with a 4k gfx u can watch HD movies @ hig rs no problem
the rest of the money if save keep it for later gfx card money or get some thing good as good speakers if music is alll that imp may be 5.1 if later u can get money ...so save it
you are a 17 yr old guy.........so dont worry this ASUS M2NPV NM has got a onboard gfx...which will let u play the games or else which wont load at all
later add a gfx and get that quality in the display !! like 8500 GT is at 4.5k
hey this mobo has no support for Quad Core as of now !! note this !!
if u go AMD way...there are no quad cores !! yet to be released and that too socket AM2+...
Reason: Automerged Doublepost
04-08-2007, 10:31 AM
Techie By Heart
thanx. i'll be going with 5000+ then. i hope imb cache won't make much of a difference & as 5000+ also has power saving it'll really be a good value for money.
04-08-2007, 10:38 AM
well i dont know how its cache affects.....it performance
but when u compare its benchmarks and performance it beats the budget C2D and come to the level of C2d E6420
check out http://www23.tomshardware.com/cpu_20...=928&chart=419
04-08-2007, 01:30 PM
Google Bot
y dont u get the 5200.. 1mb more cache ll boost ur performance.. and get a m2a vm instead of the pv vm..
04-08-2007, 01:34 PM
Techie By Heart
but hows 5200+ its power consumption??????????????
04-08-2007, 03:14 PM
UbuntuUser
I dont want to be rude but you guys are just defeating the main purpose of the thread started by choto_cheeta. Fireseeker couldve asked the question there and people wouldve replied.
04-08-2007, 05:10 PM
aks_win,
can i have the name of the shop in bangalore which sells ddr2 800 for 2100.i did ask a store near my place and he said 2400+ 4%.i am from rajajinagar area.
04-08-2007, 07:53 PM
ok then go for 5200 u shld get it for 5700 to 6000 rs dont settle for anything higher
ask any shop in SP road.......they will say 2225-2300rs bargain it
see this post
http://www.thinkdigit.com/forum/show...&postcount=109
@fireseeker check this out....i suggested 5000 on the basis of CPU charts and benchmarks...and price being about 800 - 1000 rs less then 5200
http://www.amd.com/us-en/Processors/...E13076,00.html
check this out every thing is given...even power supply
for brisbane is 65nm and windsor is 90nm
65nm has less power consumption !!!
04-08-2007, 09:49 PM
#19 (permalink)
tech mighty
go for the following config....
Core 2 duo E6750 - 8700
Intel g33 MB - 5500
Ram 1gb kingston - 1800
Seagate 250gb - 2700
Zebronics lava with 400w PSU - 1300
Total-------------------------20000
after some time u may change the PSU........
It will kill any AMD offering at the stock speed itself....if u have graphics card buy XFX 650i instead....
05-08-2007, 02:42 PM
#20 (permalink)
Techie By Heart
not interested in Intel right now.
& plzz help me choose a good amd mobo. i'm really confused which 1 to choose. so many options.
05-08-2007, 05:13 PM
#21 (permalink)
tech mighty
Not going with Intel....ha ha ha....
shows ur brand(AMD) Loyalty...
Its not wise....only u r going to lose....
go with a brand which gives u a better product....(currently it is Intel-the situation may change when Barcelona comes out)...fanboyism and brand loyalty are absolutly rubbish....
05-08-2007, 10:28 PM
#22 (permalink)
Techie By Heart
i've never used AMD before but i wanted to try it out. i no intel is better but with my budget AMD would suit me more.
& can any1 post a good amd based mobo with its features. need to go & get it 2moro.
05-08-2007, 10:53 PM
#23 (permalink)
i find ASUS M2NPV NM great AMD budget motherboard !! Me and My friend got this mobo 3 days bck for 4.2k
its got Geforce 6150 onboard !! with Shader Version 3.0 !! this shader version should allow u play games coz i have seen many games ask for shader v 3.0 !! that's why edge over M2A !!
its got HDTV out !! connect ur comp to ur TV and enjoy !!
its also comes with firewire port !!
has 1 PCI ex slot !! u can later add gfx card !!
You Can easily connect your old ide hdd and new sata hdd with no problems just see that u read the manual nicely !! that's all !!
Processor, Motherboard, HDD, Cabanite, RAM, PSU
if this all you need ???? then do an intel man !!!
Intel g33 MB - 5500
sounds good for me..........E6750 being 8k actually and if you are in mumbai or b'lore then good....u can get the above parts cheaper then mentioned
or go for E6550 @ 1k cheaper price........common this is like the best will beat ur AMD 5000+ hell
AMD 5000+ was for 15k budget upgrade dude not 20k
but i dont know if this onboard gfx is good !! and if u can play games on it !!
if not get 1 for jus 4k or may be 3k in dec....tht shld allow u play games nicely
05-08-2007, 11:18 PM
#24 (permalink)
Google Bot
if u r not goin to game then get a m2avm.. Cos the 690g outperforms the 6150se in normal gfx rendering.. The only plus of 6150 is sm3.0.. As clear as that
05-08-2007, 11:31 PM
#25 (permalink)
Techie By Heart
i'll be playing games. & isn't Transcend better than Kingston?????? Isn't WD better than Seagate????????? & i was thinking to take Zebronics Peace or Antibiotic. aren't these 2 better than Zebronics lava????????
05-08-2007, 11:36 PM
#26 (permalink)
Google Bot
yes to all above questions but isnt 30k better than 20k
06-08-2007, 03:19 PM
#27 (permalink)
Techie By Heart
yup it is but u should be having it too. LOLz!!!!!!!!
i'm putting all of my pocket money that is 15k into it. & rest is given by mom & dad.
06-08-2007, 08:52 PM
#28 (permalink)
^^ hmm so it means total of 35k ??
06-08-2007, 09:40 PM
#29 (permalink)
Techie By Heart
nope. it means total of 25K. but the other 5K i'm going to put it in buying a cell.   so 20K left for the comp. but if neccesary i'll put some from the 5K into the comp buget.
oohh ya. 1 more thing. the mobo u suggested is ATXu form. i wanted a ATX form. i'm thinking to buy the mobo from ASUS.
06-08-2007, 11:35 PM
#30 (permalink)
sorry abt it......its actually ASUS M2NPV-VM not M2NPV NM !!
its link is here http://www.asus.com/products4.aspx?l...38&modelmenu=1
check it out !!
but why not uATX form factor ?? it will fit nicely into any ATX cabinet !!
btw what do u study ??
