Old 18-07-2007, 07:36 PM   #1 (permalink)
Default a blue screen error
yesterday i have installed xp-os in my system.then it go to the welcome screen and show one error message in blue screen,i think partmanager_sys.it is the name what can i see and the error is appear in full screen.then it will restart.then i plug the ram and clean it.then i put the ram in another slot.it work fine.what can i do?please help me.wat s my problem?
thecreativeboy is offline
Old 18-07-2007, 07:41 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: a blue screen error
this is called Blue Screen of Death (BSOD)
is this screen appearing again........?
satyamy is offline
Old 18-07-2007, 07:44 PM   #3 (permalink)
it could be a RAM slot defect. did u try to put the RAM in the same slot after cleaning
kooabs03 is offline
Old 18-07-2007, 08:17 PM   #4 (permalink)
ram slot is defected
abhijangda is offline
Old 19-07-2007, 04:36 PM   #5 (permalink)
yes the screen is appearing again and again.then i remove the ram in the slot and put the ram in another slot it will work fine for one day or somewhat.then the blue screen have appears again.then i remove the ram in the slot and put in another slot it will work fine again.is it the ram slot is defected?the system has warranty also.what can i do.can i manually repair the ram slot?what can i do?please help me..
Old 19-07-2007, 08:00 PM   #6 (permalink)
do not try to repair it urself. it will void warranty. get it repaired if its under warranty. but does it happen with both the slots? if yes maybe the RAM is faulty.
kooabs03 is offline
Old 20-07-2007, 12:52 PM   #7 (permalink)
hi friends,
thank you to everyone for ur valuable advice.
error a blue screen.... niku_19jan Software Q&A 7 29-11-2006 10:40 PM
Blue screen error!!! shay4u QnA (read only) 7 30-11-2005 09:48 PM
blue screen error!!! shay4u QnA (read only) 5 29-11-2005 08:46 PM
Blue error Screen in XP Ashootosh QnA (read only) 6 24-01-2005 09:49 PM
Blue Screen Error bipin_hbk QnA (read only) 5 01-09-2004 09:27 PM
- by kool
