Old 17-07-2007, 09:30 PM   #1 (permalink)
Red face help needed in buying a bluetooth USB dongle
I hav Nokia 6111 phone and i got it frm germany.i was surprised that it didnot hav any pc connector(USB) for it.now can i buy usb cable for it or else should i opt for bluetooth USB dongle.Can any one say which is the perfect bluetooth USB dongle and also its price plz.
Hari_04415 is offline
Old 17-07-2007, 10:36 PM   #2 (permalink)
Default Re: help needed in buying a bluetooth USB dongle
Nokia 6111 doesnt have USB connectivity AFAIK (even though the website specs indicate USB port, one I purchased in India did not). Check out the manual to be sure. It does have Bluetooth connectivity... So, you will have to get a Bluetooth USB dongle - any generic model should do and will set you back by about 500-600 bucks I think...
Arun
sakumar79 is offline
Old 17-07-2007, 11:20 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Dongles with s/w from BlueSoil are the most popular and best as well I guess, I have bluesoil, havent faced any issues till now.
sam9s is online now
Old 18-07-2007, 08:39 PM   #4 (permalink)
Ganeshkumar's Avatar
My frnd got local bluetooth dongle for Rs.200 and think working properly!
or If ur cell has memory slot, u can also buy memory card reader!
Ganeshkumar is offline
Old 18-07-2007, 09:28 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: help needed in buying a bluetooth USB dongle
use any all are good
it will come around Rs. 200-250
satyamy is offline
What Bluetooth Dongle??? linardni Mobiles and Tablets 11 29-07-2009 06:26 PM
enter bluetooth dongle viruses Mobiles and Tablets 15 17-07-2008 09:03 AM
Bluetooth USB Dongle GeekyBoy Peripherals 1 31-12-2006 01:11 PM
Bluetooth USB dongle Devrath.N.D Hardware Q&A 2 28-06-2006 06:44 PM
Buyin Bluetooth Dongle For Nokia Phone ? Read This First din QnA (read only) 10 15-10-2005 07:40 AM
- by kool
