Old 17-07-2007, 09:03 AM   #1 (permalink)
arachnoid
Posts: n/a
Default 19 inch lcd
i have decided to go in for 19 inch lcd monitor but confused which model and make to go for ( viewsonic, samsung, etc.) ...
please suggest which lcd should i go for and its approx. market price ...
my budget is 8-12 k.
p.s. i have gone through the whole sticky of latest hardware prices and quotes and related sticky's and posts and found nothing quantitative. so please refrain from referring to anywhere
Old 17-07-2007, 09:29 AM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: 19 inch lcd
Viewsonic 1912wb will be available for around 11.5k. But it doesn't have a digital input, so u can try to go for Samsung SyncMaster BW series. It will be available for 13k but worth it.
www.nerdweed.blogspot.com
casanova is offline
Old 17-07-2007, 09:32 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
I bought this one, of View Sonic, for Rs. 13k incl TAX 2 months ago from Kolkata...
http://www.viewsonic.com/products/lc...ries/vg1930wm/
Good performance...
should come under 13k with TAX !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 18-07-2007, 07:47 AM   #4 (permalink)
2 days back i purchased viewsonic VA1912WB @ Rs 9400/- from lamington rd.
This model has both DIGITAL and ANALOG inputs gives u the best bang for the buck
it has another version VA1912W which has specs same as above but lacks the DIGITAL input and costs around Rs 9350/-
Given the little price difference the VA1912WB is a gud choice amongst the two
C2D E7500, Geforce GTS 250, Panasonic 42" Plasma P42V20D
Samsung Galaxy SL i9003
xtremedia is offline
Old 18-07-2007, 09:29 AM   #5 (permalink)
arachnoid
Posts: n/a
i had already shortlisted viewsonic va1930wm .. but had second thoughts after reading some negative postd about viewsonic ....
and "chota cheeta" ... where in kol did u buy it from ???? the distributor of viesonic in kol is i think "supreme" ... and bloody when i started bargaining ... they began lecturing me how they can control the market price and the best deal is only offered by them ... they quoted 9k for va1903wm ( not va1930wm) .... but after roaming through chadni a bit i got to 8.8k
what do you people suggest bout dell monitors .... r they worth going for? and do you know if they deliver in kol or not?
Old 18-07-2007, 10:56 AM   #6 (permalink)
Rebooting
You are right !!! me too bought it from Supreem but not from retailing counter they quited a lot and also demanded i havbe to buy the full system config otherwise they wont sell it... !!!
Therefore I took help of a friend of mine who has another frnd who owns a computer shop...
So we went to supreem Vendors counter in the 4th floor to get the LCD out on the name of that Shop
Little Trick
rebooting
ChotoCheeta.com
Old 18-07-2007, 12:38 PM   #7 (permalink)
Phalanx's Avatar
VG1930wm is an awesome monitor...
C2D E4300, MSI P6N SLI Platinum, Transcend 2GB 667MHz, XFX 8600GT, Viewsonic VG1930wm, Seagate 250GB SATAII, Lite-On LH-20A1P, Compro VideoMate X50, Microsoft wireless KB and Mouse, iBall Grabit.....
Phalanx is offline
Old 18-07-2007, 12:47 PM   #8 (permalink)
thug for life...2pac
PainKiller's Avatar
im planning to buy 1930wm but have a few doubts:
1) in specification, it says 1930wm has a response time of 5ms...is it good for games...will it create any ghosting effect.
2) operating Temperature 41-95°F (3-35°C) - in delhi it goes to 46°C. will it create any problem.
3) whats diff. b/w digital input and analog input??
e8400:)|abit ip35-e|transcend 1x2gb 800mhz|evga 8800gt sc:)|wd 320gb sataII|moser baer 20x sata|corsair vx 450w:)|cm elite 332|altec lansing atp3:)|15" crt (lg 226wtq soon)|kboard/mouse:samsung/ms
PainKiller is offline
Old 18-07-2007, 12:51 PM   #9 (permalink)
Rebooting
http://en.wikipedia.org/wiki/Digital_Visual_Interface
rebooting
ChotoCheeta.com
Old 18-07-2007, 06:33 PM   #10 (permalink)
 Macboy
goobimama's Avatar
9.4k! Thats ****in-A dude! I might get one of those to do a dual monitor setup. How much would a 20" widescreen cost?
I'm like a bird... :)
goobimama is offline
19 inch LCD and 17 inch LCD morpheusv6 TVs / Monitors 9 02-01-2007 11:22 PM
21 inch Monitor Varunnagwekar QnA (read only) 1 24-05-2005 03:45 PM
21 inch monitors Hulo QnA (read only) 3 26-04-2005 11:38 AM
19 inch monitor or 15 inch lcd ? dipdude1 TVs / Monitors 16 04-04-2005 10:03 AM
29 inch TV Shikhar QnA (read only) 2 16-10-2004 04:17 AM
- by kool
