Old 17-07-2007, 12:17 AM   #1 (permalink)
mak1012's Avatar
Angry I'm having any hardware problm????????
hi,
in last one week i have formated my drives twise? becuase it gets freaze sometime.....
i was having an virus problm but after formating and running system twice with three antivirus still today my system got freeze,
I'm having any hardware problm??????(yesterday i formated my drive and installed fresh copy of XP)
Every Body Says I'm Fine.
mak1012 is offline
Old 17-07-2007, 12:42 AM   #2 (permalink)
slugger's Avatar
Default Re: I'm having any hardware problm????????
ru running all 3 avs all @ d same time?? BIG mistake if u do so. if not u also mentioned sumtimes. if dat is d case wat exactly do u do when u face this problem?
u cud also b facing heat issues, is ur CPU fan working properly, is sumthin' obstructing d airflow [big time] check out d temp of ur cpu when it freezes [actually if ur comp freezes u r facing extremely low temp , hangs maybe]
u cud use on of d monitors
heres 1
Motherboard Monitor 5.3.7.0
slugger is offline
Old 17-07-2007, 01:10 AM   #3 (permalink)
mak1012's Avatar
no i'm ot doing any mistake i used them seprately. i restart my pc again.
it might be possible i'll fix them... then i'll check..
but in MBM i'm not getting the option for motherbord i'm using D915gav.
mak1012 is offline
Old 17-07-2007, 01:22 AM   #4 (permalink)
slugger's Avatar
by usin' them seperately do u mean all 3 r installed @ d same time but u run an on-demand scan only 1 at a time. if dats d case den u shud know dat realtime scanners keep a check in d background even wen u do not demand a scan and dis does cause magor problems
also o u did not say as 2 wat exactly u do wen ur comp goes kaput
slugger is offline
Old 17-07-2007, 02:02 PM   #5 (permalink)
mak1012's Avatar
at a time in my system i install only one antivirus....
when my system freezes i restart the system.
mak1012 is offline
Old 17-07-2007, 03:21 PM   #6 (permalink)
Originally Posted by mak1012
hi,
Congratulations!
apacheman is offline
Old 17-07-2007, 11:15 PM   #7 (permalink)
mak1012's Avatar
Originally Posted by apacheman
Congratulations!
mak1012 is offline
Old 17-07-2007, 11:45 PM   #8 (permalink)
check ur hardware temp using speedfan..maybe its getting too much heated..give ur pc a days rest and recheck...And use only one anti-virus software like Kaspersky. Its quite good and runs on low resources.
Abhishek Bhattacharya
abhishek_del is offline
Old 18-07-2007, 08:13 PM   #9 (permalink)
mak1012's Avatar
I installed speed fan its showing me cpu temp. 61-66c.
it freezes once at temp of 61c. now its showing
what is ideal temp for cpu?
mak1012 is offline
Old 18-07-2007, 10:43 PM   #10 (permalink)
wat cpu do u have ? the cpu temp is quite high unless u've OCed it pretty much . mu p4 presshot runs at 49c on idle and maxes at 56C .
sagargv is offline
Old 18-07-2007, 11:10 PM   #11 (permalink)
mak1012's Avatar
i have P4 and motherbord intel D915 gav.
if my my pc is to hot then what to do now?
mak1012 is offline
Old 19-07-2007, 01:38 PM   #12 (permalink)
slugger's Avatar
y don't u remove d processor fan, srape off d old thermal paste and apply a fresh coat of thermal paste like Artic Silver, then put d fan back on, den c if it solves ur problem, since P4s have a covered core it is not dat risky, just do it carefully
btw either DIGIT gave a brief description of doing this in their July 2007 issues page 73
slugger is offline
Old 19-07-2007, 03:46 PM   #13 (permalink)
mak1012's Avatar
remove d processor fan means i have to change that tooo?
how much is cost for a thermal paste?
mak1012 is offline
Old 20-07-2007, 03:35 PM   #14 (permalink)
slugger's Avatar
no no u don't have 2 buy a new fan [if dat is wat u interpreted]
all u gotta do is seperate it form d processor
it is usually attached 2 d processor using a clip arrangement
as 4 d cost of a tube of artic silver thremal paste, it will set u back by 150-200 bucks no more.
shud b easily available in Lammy
slugger is offline
problm in booting FC4 mak1012 Open Source 8 29-08-2006 11:27 AM
HELP...! BSOD, graphics problm Kniwor Graphic cards 5 18-03-2006 05:39 PM
IDA problm bholu QnA (read only) 1 21-12-2005 11:12 AM
Help!!!! problm with Graphics cool_dude_prav Graphic cards 2 04-09-2004 01:44 PM
- by kool
