Old 15-07-2007, 10:31 PM   #1 (permalink)
]-[ E l l F R 4 G G 3 R
frederick_benny_digit's Avatar
Default 7600gs or 8500GT ?????
I have a budget of Rs.5-6K.Plz suggest if I should go for XFX 7600GS or 8500GT.I know 7600GT is miles ahead of both of these,but I cant afford that.I am an avg gamer,play CS 1.6 a lot,n wanna try out S.T.A.L.K.E.R.
The DX10 support really entises me in 8500GT……plz reply soon…
"C++" should have been called "D" !!! :D:D:D
frederick_benny_digit is offline
Old 15-07-2007, 10:40 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: 7600gs or 8500GT ?????
get a xfx 256mb gddr3 8600gt 6.8k
Pathik is offline
Old 16-07-2007, 09:44 AM   #3 (permalink)
avoid double posts . hey , i bought a xfx8600gt for 8.2 k 3 weeks back...
sagargv is offline
Old 16-07-2007, 10:33 AM   #4 (permalink)
At http://www.deltapage.com/graphic.htm (chennai shop), you can find zebronic 256MB 8600GT for 6.8k... It may be the best bet for you... If you want to restrict to 5-6k, I would recommend 7600 because I have read a few reviews that trash the 8500 card...
Arun
sakumar79 is offline
7600GS or 8500GT ???? frederick_benny_digit Gamerz 7 16-07-2007 08:05 AM
8500GT or 8600GT s18000rpm Hardware Q&A 43 17-06-2007 10:55 AM
Installing linux with 8500GT card baccilus Open Source 8 25-05-2007 11:48 PM
XFX Launches 8500GT, 8600GT, 8600GTS in India Pathik Technology News 7 01-05-2007 01:55 AM
7600GS or GT?? dOm1naTOr Hardware Q&A 10 05-08-2006 10:01 AM
- by kool
