14-07-2007, 10:33 AM
Cool and Calm
533 or 400?
i hav a hp pavilion m7260in pc....
it says it has a 533MHz FSB....bu i hav a 400Mhz(Edited) 256mb ddr2 ram....
can i use a 533Mhz 1gb ram module on my pc?
When Roger's at play, opponents pray..!!!!! :twisted:
14-07-2007, 10:44 AM
Alive Again...
Re: 533 or 400?
14-07-2007, 11:28 AM
Cool and Calm
Re: 533 or 400?
thanks...
but it says "speed supported is PC2-3200 MB/sec"....
if it is pc2-3200, the it is 400MHz....
so is it speed of FSB wich matters for the type of ram(400/533)?
14-07-2007, 11:33 AM
Re: 533 or 400?
u cannot use 533Mhz RAM coz its DDR2 and your system has DDR1 slot
14-07-2007, 11:36 AM
Cool and Calm
Re: 533 or 400?
hey, i hav 400Mhz DDR2 RAM........
14-07-2007, 11:57 AM
Re: 533 or 400?
which mobo do you have? i mean chipset. also 400MHz is a DDR1 RAM. its a 184 pin RAM. DDR2 is 240 pin RAM.
14-07-2007, 12:44 PM
Re: 533 or 400?
DDR2 speeds start from 533Mhz... Yours is surely a DDR variety...
14-07-2007, 12:58 PM
Cool and Calm
Re: 533 or 400?
thanks....
see my specs:
Memory Installed 256 MB (1 x 256)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of installed 256 MB DIMM
Speed supported PC2-3200 MB/sec
Type 240 pin, DDR2 SDRAM
DIMM slots Four
Open DIMM slots Three
14-07-2007, 01:00 PM
Re: 533 or 400?
@ Choto Cheeta
my miskate...  Thanks for the info mate...
14-07-2007, 02:22 PM
a_g = JPKN
Re: 533 or 400?
whats FSB got to do with RAM speed support?
Intel® 915P Chipset Features
Dual-channel DDR2 or DDR
Flexible memory support, for dual-channel DDR2 533/DDR2 400 or DDR400/DDR333 memory, in configurations of up to 4 GB RAM.
make sure your m/b has DDR2 support.
download CPU-Z & check.
direct download link
ASUS K53SV SX520D + BF3
14-07-2007, 04:35 PM
Cool and Calm
Re: 533 or 400?
thanks s18 ....
but FSB does matter.....
if u r havin a 400MHz FSB and if u run a 533 mhz ram module, i think it wont work.... 'front side bus' ....this is used for all kinds of data transfers on ur comp...be it with cpu,memory,hard disk,etc.....
14-07-2007, 04:42 PM
Rebooting
Re: 533 or 400?
@s18000rpm
@abhi_10_20
There is a cacth here, see if you buy a 800 MHz RAM module, that will be able to oparate uder 533 MHz or 667 MHz...
but the problem is none of the present DDR-II Supports that 400 MHz RAM...
very very few modules of 400 MHz was even pruduced, better option is just by one Higher 533/667 MHz RAM module...
rebooting
ChotoCheeta.com
14-07-2007, 05:18 PM
a_g = JPKN
Re: 533 or 400?
thanks s18 ....
it does work, it wont work on its max. speed, but it'll work, coz i'm running DDR2 800MHZ RAM @ 533MHz  with P4 3.06GHz (533MHz FSB, same as urs).
i cant run it above this speed (533), i'll be getting C2D soon, so then only i'll be be able to run the modules at 800MHz & OC them
14-07-2007, 05:23 PM
Rebooting
Re: 533 or 400?
Hey u missed my post
2days DDR-II supports 533 / 667 / 800, but problem is they are not designed to go bellow it, and if even u force them to go bellow that, and run at 400 MHz stability issue will come up....
rebooting
ChotoCheeta.com
14-07-2007, 05:30 PM
a_g = JPKN
Re: 533 or 400?
no i didnt miss your post
it seems his m/b supports 533MHz speed (read my post #11).
abhi, read the PC manual or d/l "Lavalys EVEREST" & confirm whether your m/b supports 533Mhz (probably it shud).
14-07-2007, 05:52 PM
Rebooting
Re: 533 or 400?
It does support 533 MHz but point I am concern is as he wants to run the default suplied 400 MHz RAM along side of the 533 MHz ram !!!
rebooting
ChotoCheeta.com
14-07-2007, 06:11 PM
Cool and Calm
Re: 533 or 400?
no no no......
i wanna remove the 400 mhz one completely.....
see, if i get another 400 mhz 1 gb ram , it wd cost me more...
as the vendor said the 400 mhz one is out of date and hasnt gud supply....
hence i thought to get a cheaper 533mhz one and use it only..
14-07-2007, 06:14 PM
#19 (permalink)
Rebooting
Re: 533 or 400?
As per as ur PC product url posted above... u can use DDR-II 533 MHz RAM for sure with out any problem
rebooting
ChotoCheeta.com
14-07-2007, 06:16 PM
#20 (permalink)
Cool and Calm
Re: 533 or 400?
thanks....
14-07-2007, 06:32 PM
#21 (permalink)
Re: 533 or 400?
intel 915 chipset supporting DDR1 RAM  . but it sure supports DDR2
14-07-2007, 06:41 PM
#22 (permalink)
Rebooting
Re: 533 or 400?
rebooting
ChotoCheeta.com
14-07-2007, 06:59 PM
#23 (permalink)
Re: 533 or 400?
oops.. my bad! put the DDRs ohter way. but does the board support both DDR1 and DDR2? i had a mercury board which supported both SDRAM and DDR. dunno about this.
14-07-2007, 07:02 PM
#24 (permalink)
Rebooting
Re: 533 or 400?
There are boards which support both DDR and DDR-II but none of the Intel Original 915 based boards had that option !!!
rebooting
ChotoCheeta.com
14-07-2007, 07:22 PM
#25 (permalink)
Re: 533 or 400?
y dont u guys just read the mobo manual
it clearly says which ram speeds it can support
14-07-2007, 10:56 PM
#26 (permalink)
Rebooting
Re: 533 or 400?
Some time Manual which comes with Branded PC is not quite good  to provide such information  rather gives graphical images of how to install Drivers and stuff like that
rebooting
ChotoCheeta.com
18-07-2007, 06:26 PM
#27 (permalink)
Cool and Calm
Re: 533 or 400?
Hi all....
neither 400 nor 533......i got a 667 MHz one....
i am running both the earlier 400MHz one along with the 667MHz one....
everything seems to be fine....
wouldnt there be any problem with wat i am using now???
hello....
Reason: Automerged Doublepost
18-07-2007, 08:58 PM
#28 (permalink)
Rebooting
Re: 533 or 400?
Hi all....
hey !!!
u should not run a 533 / 667 MHz ram with another 400 MHz RAM.... they are not (533 or present available 667 MHz 240pin DDR-II) designed to go that low...
run only that 667 MHz RAM...
u may end up with a burned ram module
rebooting
ChotoCheeta.com
18-07-2007, 09:56 PM
#29 (permalink)
Cool and Calm
Re: 533 or 400?
but everything is working fine....
even the vendor told it wouldnt give a problem.....
i think the 400Mz one is running in its own clock speed and the other one in its own..... isnt that possible?
18-07-2007, 09:59 PM
#30 (permalink)
Rebooting
Re: 533 or 400?
No, the 667 MHz is running at Under clocked speed of 400 MHz...
anyway i just suggested you what migh happen, so, its not certain that it will happen, when ur vendor says it will run, then let it be there... run togather.... but if some thing happens, do post back here
rebooting
ChotoCheeta.com
