Re: didnt format the c drive
AFAIK you cannot format your C: drive if your OS is installed on the same drive.
But now since you have installed your OS on D: then you should try it again, If nothing happens then do a *thorough* scan disk check and see if your drive has bad sectors. If it has then they will be marked as "bad" and then youll be able to format your C: drive.
