Old 13-07-2007, 10:45 AM   #1 (permalink)
din
Tribal Boy
din's Avatar
Default HDD for backup - SATA or Normal ?
I have 2 PCs working more than 16 hrs a day and I am planning to get 2 160 GB HDD for these for backup purposes. At present these PCs has 80 GB HDD each. Like if the present HDD fails, I can use the backup HDD to continue working without reinstalling everything (using GHOST or something).Thats my plan.
The normal HDD and SATA HDD, there is considerable difference in speed/performance ? Which one I should go ? Another thing is, I think (is there any way to check ?) my Motherboard does not support SATA, so if I want to buy SATA HDD, I may need to change things from motherboard itself ! It worth changing ?
Oh, I just saw the motherboard box, it is written - Asrock K7VM4. No SATA it seems ...
Also, any recommendation on brand ? Or all same ?
And finally, whats EIDE ? Please enlighten me
Thanks ain advance.
din is offline
Old 13-07-2007, 12:27 PM   #2 (permalink)
Default Re: HDD for backup - SATA or Normal ?
If sata is suported then you should buy sata hdd, so later when u upgrade the comp u have a compatible hdd, I did so last year & bought a IDE 2 sata convertor for Rs 500/ & used it till I upgraded.
Just for ur info the ghost image can be written to CD/dvd so just for doing that u don't need a new hdd.The image it creates is compressed so when hdd fails &you need to restore all u need is to restore from that image in dos mode & u will be back & running .
ranjan2001 is offline
Old 13-07-2007, 12:36 PM   #3 (permalink)
din
Tribal Boy
din's Avatar
Thank you for the info ranjan.
IDE 2 sata convertor - is it something like a cable or a PCI card ? After using it you felt the speed/perfomance difference ?
Yes, I use Ghost / TrueImage now, making into DVDs. But I was thinking of buying HDD as prices came down a lot.
din is offline
Old 13-07-2007, 10:45 PM   #4 (permalink)
UbuntuUser
cynosure's Avatar
For better referance see this
Yes I think that HDD will be a better idea than DVD/CD as you can store much more data on HDD. And DVD will be ruined if you somehow a scratch is developed over it, but HDD will keep on going (Unless ofcourse you give it a very powerful blow)
cynosure is offline
Old 13-07-2007, 10:47 PM   #5 (permalink)
The Unknown's Avatar
If SATA is supported, then buy SATA.
KDE on ArchLinux
The Unknown is offline
Old 13-07-2007, 11:19 PM   #6 (permalink)
Yes this is the card I bought, it fits into the IDE port on the mobo & there is a delay of 10 sec in booting, but taht hardly matter to me since I reboot once a week only or maybe when I install a new program.
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
How to connect SATA HDD to a mobo w/o SATA port ashnik Hardware Q&A 7 31-03-2006 08:52 PM
registry backup means hd backup????? magnet QnA (read only) 3 01-04-2005 11:00 PM
- by kool
