Old 12-07-2007, 09:26 PM   #1 (permalink)
Default Flicker on Monitor - Only if tapped
I have an old 14” CRT Monitor, > 5 years.
Now when I turn on the PC, any slight tapping around the table etc results into a short flicker on monitor.
As such the flicker happens only if I tap the table or casing on the monitor..otherwise there’s no flicker as such. Also it stops after some time.
What could this be indicative of?
Thanks.
patkim is offline
Old 12-07-2007, 10:13 PM   #2 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Default Re: Flicker on Monitor - Only if tapped
^^Monitor dying out...time to get an LCD
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 12-07-2007, 10:43 PM   #3 (permalink)
Loose contact in the circuit, possibly. Best thing is to replace and not to repair.
V.Prem Kumar
janitha is offline
Old 12-07-2007, 11:05 PM   #4 (permalink)
Ok..just another question in conjuction..
how to connect LCD Monitor to VGA out ..is there a connectivity/ plug or some adapter is required..
patkim is offline
Old 12-07-2007, 11:16 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
no u dont need any thing
they are same
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-07-2007, 07:58 AM   #6 (permalink)
Almost all LCD monitors have VGA as well as DVI inputs. (some don't have DVI)
V.Prem Kumar
janitha is offline
29'' tv as monitor gr8usr QnA (read only) 8 22-12-2006 01:37 AM
ps2 on the monitor?? deepinder_mann1988 Gamerz 2 16-06-2006 08:34 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
Need new Monitor.. foreveranuj QnA (read only) 11 28-03-2005 11:33 PM
Best Monitor AMD QnA (read only) 2 18-03-2005 12:43 AM
- by kool
