Old 10-07-2007, 11:33 PM   #1 (permalink)
Lightbulb suggestion:For a good AGP card
friends Pls suggest me to buy an good AGP card...
I have,
Intel original 865GBF Motherboard
Intel P4 2.0 Ghz
1GB RAM
i need a AGP card should support the aboue config.. and also VISTA
i had Plan to buy XFX 7300GT 512MB AGP card ,whether it is supported or is there any athoer good agp card....
Thanks with
Regards
rockstar24 is offline
Old 10-07-2007, 11:58 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: suggestion:For a good AGP card
even 6200 supports Vista
but see non iof them will support DX10
I would recomend 256 MB ATi x1600 Pro AGP gives 4.9 gaming grfx rating with Vista....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-07-2007, 12:00 AM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
yeah.. or you can even get a nvidia 6600. any card wid 512mb memory will be an overkill for ur system. why spend that much??!!!
infra_red_dude is offline
Old 11-07-2007, 09:44 AM   #4 (permalink)
ur budget ??
sagargv is offline
Old 11-07-2007, 07:58 PM   #5 (permalink)
my budget is 6000 R.S
Old 11-07-2007, 10:53 PM   #6 (permalink)
Rebooting
well i guess x1600 Pro 256 MB AGP may come in that budget !!!
rebooting
ChotoCheeta.com
Old 11-07-2007, 10:55 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
7300 series doesn't let you play a few games, I heard Lost Planet and a few others don't support it or something. Its an ATi x1600 or a 7600GS for your budget.
Harsh J
www.harshj.com
QwertyManiac is offline
Can any 1 give good suggestion sakthirajesh Hardware Q&A 7 03-12-2006 03:17 AM
Suggestion to buy a good game karthik_rcs Gamerz 17 22-10-2006 10:39 PM
- by kool
