Old 09-07-2007, 09:26 PM   #1 (permalink)
Default Zone Alarm Security Suite problem
hello,
i have installed ZASS 7. Since then machine has become extremely slow. switching off takes more than 3 minutes. twice it has dumped physical memory. please let me know if i can do anything to rectify it before contacting ZoneLabs.
thanks
tech_lover is offline
Old 10-07-2007, 01:37 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: Zone Alarm Security Suite problem
revert back 2 zonea - 6.5 or later .........
7 tends 2 use more RAM ...... & thus slowing down .........
... W H O T ...
ax3 is offline
Old 10-07-2007, 07:47 PM   #3 (permalink)
in search of myself
CadCrazy's Avatar
what if i have vista ??????????
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 10-07-2007, 08:00 PM   #4 (permalink)
Back in Power
almighty's Avatar
ZA don support vista yet
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 10-07-2007, 10:49 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
ZA now supports vista ^ ! buddy. its out of beta, but stl reprtedly giving problems. so best to stay away from the vista za, till ir settles down.
za7 on xp is heavier yes. but i sgst u remove it from ur startups and use it ONLY when u r on the net.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-07-2007, 10:54 PM   #6 (permalink)
thanks, dunno if the license will work though! may be i'll add more ram
will try that too. only thing is that i shouldnt forget. is there any way to ensure that ZA starts as soon as I connect to any outside network/Net?
Zone Alarm godsownman QnA (read only) 21 08-10-2005 10:50 PM
xp,zone alarm or me? mariner Software Q&A 12 08-09-2005 01:59 PM
Zone Alarm Security Suite 5.5.062.011 Issue nipun_the_gr8 QnA (read only) 3 30-06-2005 12:29 AM
Zone Alarm pro help ! ! ! ax3 QnA (read only) 4 08-04-2005 11:28 AM
Zone alarm rahulbpatil QnA (read only) 3 08-09-2004 03:58 PM
- by kool
