Old 09-07-2007, 01:37 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default Urgent!!!!- Forgot Boot password!!
My friend has forgotten the boot password on his hp desktop,,
we've tried takin out the Cmos battery but nothin is happenin.. plz help!!!!
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 09-07-2007, 02:21 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Urgent!!!!- Forgot Boot password!!
^^ Now a days most BIOS are EEPROM so taking out battery will not work. There will be a 3 pin resert Jumper (two connected and one leftout )on the mother board for resetting BIOS. Just take out the jumper and connect it the other way round.This should fix the problem. as its a branded computer I think there will be no motherboard manual. Search for a 3 pin jumper on the board.Most probabaly it will be located near the battery.
Charan is offline
Old 09-07-2007, 02:26 PM   #3 (permalink)
NP : Crysis
xbonez's Avatar
^^yup it'll work that way. i've done it often. disconnect the pc, remove the battery, move the jumper cap to pins 2 and 3, leave it for about 20sec. after that, put the jumper cap back to pins 1and2, put in the cmos batt and power on ur sys. all bios settings get reset to default resetting the password
xbonez is offline
Forgot password of XP pritish_kul2 Software Q&A 9 07-06-2007 05:35 PM
forgot my password in xp ajay1287 Software Q&A 11 15-02-2007 06:26 PM
Forgot Password of XP nitesh872004 Software Q&A 3 21-08-2006 12:50 PM
forgot win password. supersaiyan Software Q&A 24 17-01-2006 01:14 AM
Forgot Your Password On XP? readermaniax Tutorials 6 12-12-2005 02:22 AM
- by kool
