Old 09-07-2007, 12:05 AM   #1 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Unhappy keyboard not working properly
some of the keys in my intex keyboard r not working properly
some times they work sometime not even when i press them hard . i have
tried to rectify this by opening keyboard (cos its out of warranty) and
replacing rubber below the culprit keys but all in vain
what should i do ? can this prob be rectified or should i go for a
new one ( suggest which one ) ?
saurabh kakkar is offline
Old 09-07-2007, 12:10 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: keyboard not working properly
Key boards are available from Rs. 140 and mind u once we bought few ZION and Amkate keyboards for our Cafe use, and man I compare them with TVS Gold !!! Those ZION and Amkate boards are running as good as TVS gold taking some much Public pounding !!!
so its better u invest few bucks on a new one rather trying and wasting time with the old one
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-07-2007, 12:20 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Normal cause of such problem is deposition of moisture and dust below the keys.
ravi_9793 is offline
Old 09-07-2007, 12:30 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Were they as comfortable as TVS and more importantly, were they all Mechanical too?
@author - Get a new keyboard, it doesn't hurt .. Just try and pick anyone of Logitech or Microsoft. I wouldn't recommend wireless unless you got a real big screen and can work far off from your computer.
Harsh J
www.harshj.com
QwertyManiac is offline
Help-Pendrive not working properly!! rajivrocks Software Q&A 11 16-03-2007 01:15 AM
DVD writer not working properly blacklisted Hardware Q&A 12 31-07-2006 10:40 AM
DVD drive not working properly.. windchimes Hardware Q&A 4 04-07-2006 08:17 PM
CD Rom Drive not working properly Tech&ME QnA (read only) 6 17-11-2004 01:04 AM
- by kool
