Old 08-07-2007, 07:23 PM   #1 (permalink)
mohitgiri's Avatar
Default pc starts but no display
m facing probleam on my 2 yr old pc. whenever i switched on its run but monitor doesent starts. i also cleand my ram but probleam continus. help me
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 08-07-2007, 10:55 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: pc starts but no display
does the monitor led blink???
Pathik is offline
Old 09-07-2007, 12:24 AM   #3 (permalink)
ayush_chh's Avatar
check the cables......
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 09-07-2007, 12:47 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Do you hear any beep sound at startup???
ravi_9793 is offline
Old 10-07-2007, 12:27 PM   #5 (permalink)
mohitgiri's Avatar
all cables are ok. there is no beep sound in startup. and monitor flashing green light as like pc is off
MOHIT GIRI GOSWAMI
Old 10-07-2007, 12:33 PM   #6 (permalink)
ayush_chh's Avatar
do you have graphics card???
Old 10-07-2007, 01:34 PM   #7 (permalink)
pritishpaul's Avatar
heh dude i faced this prob three times....there is only one way man....take ur harddisk tu another pc.and put ur harddrive as the slave in that pc..hope u know hat how to do...then boot their and fix ur display driver first....if the prob continues....then simply format..
pritishpaul is offline
Old 10-07-2007, 01:42 PM   #8 (permalink)
slugger's Avatar
hey guys, i 2 face this problem when i use my old 15" CRT monitor.
dis is wat i do [absolutely serious]
after switching on the mains i count till 7 [relaxed counting] and then i press the button on the cabinet 2 start d computer. then d comp starts without any problem, else my monitor led justs blinks on and off
actually at the end of the 4rth count, i hear a click in the monitor after which d monitor starts without problems
slugger is offline
Old 10-07-2007, 02:13 PM   #9 (permalink)
Kalyan's Avatar
Hey guyz.. check the keyboard cable. My friend got the same trouble. His problem was with the keyboard ps2 connector. we booted the system without the keyboard and it did run well. just might be a cause for you.
Hope this works.. Thanks
Kalyan is offline
Old 10-07-2007, 03:38 PM   #10 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
buddy disconnent ur moniter wires from motherboard nd then plugin ur
moniter power supply to power socket then check whether u r able to see
any display if yes then ur motherboard is culprit else ur moniter has
gone .
i got the exactly same problem motherboard was the culprit in my case it
breakdown while i was playing "unreal" cos of heat ( my cpu was not properly
ventelated )
hope this will help
saurabh kakkar is offline
My Pc Starts on second attempt only. Ishan QnA (read only) 2 30-07-2006 01:23 PM
Blu-Ray disc production starts in US ssdivisiongermany1933 Technology News 6 01-06-2006 11:53 PM
NFS UG2 Crashes as it starts krish Gamerz 3 05-05-2006 11:45 AM
Can't starts new applications debrajrakshit QnA (read only) 9 11-11-2005 12:56 AM
- by kool
