Hi Techies,
I intend to setup wireless network @ home between my desktop and laptop and perform following operations:
1. Connect & logon to SIFY broadband directly using wireless. (I suppose i need a router).
2. Connect my desktop to SIFY broaband using wired or wireless.
3. Connect my laptop to desktop using wireless. I heard of ad-hoc connection but is it possible using router.
4. Connect my laptop to desktop using wireless and share internet on both systems. Let the desktop be the primary system to connect to SIFY and then share internet to my laptop.
When i seached on the net i came to know that i should by a wireless router and wireless adaptor (Not sure wireless USB or LAN).
Techies, please help me setup this network and it would be great if you could explain the step by step process to configure in order to achieve the above said connections. Also it would be great if you could suggest which range router to purchase because my desktop where i want to setup router is upstair and i shud be able to connect using laptop from ground floor. Just to let inform you, its duplex house and with a distance of 100 mts between the 2 places.
Early reply would be appreciated.
Note to moderator: I know i shud be searching in forum before asking the question but trust me i have digged into it and got a lot of info but was confused so created a new thread.
Thanks & Regards
Dev
