Old 06-07-2007, 10:12 PM   #1 (permalink)
Exclamation Two Ethernet Controllers on Same PC?
Hi All,
I have Two PC's with WinXp. Each PC got Onboard Ethernet Controller.
Also got ADSL Connection (With Ethernet Interface).
Problem is
1. How can i Put Both Computers on LAN cosidering the fact that I Also got ADSL Connection (With Ethernet Interface).
Limitations: Low/No Budget for Additional Hardware
Can I Have Two Ethernet Controllers on Same PC?
idea is offline
Old 07-07-2007, 12:04 AM   #2 (permalink)
Default Re: Two Ethernet Controllers on Same PC?
Ya sure.You may then use a crossover cable between the 2 pc's.
sashijoseph is offline
Old 07-07-2007, 01:00 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
U may refer to this thread, see if that helps a bit
Reference Guide on How to Share DataOne Connection....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-07-2007, 03:20 PM   #4 (permalink)
Thank you for your time and Advice Guys .... Choto Cheeta you are great !!
Some How I am not Able to Put Second Ethernet Card on same PC (having Onboard Ethernet Controller). It give me "Error 10" Please See Pic Attached.
Tried Changing Slot
Also Updated Latest Driver.
Please Help.
idea is offline
Old 07-07-2007, 03:24 PM   #5 (permalink)
Rebooting
Where ???
rebooting
ChotoCheeta.com
Old 07-07-2007, 03:26 PM   #6 (permalink)
now attached.
idea is offline
Old 07-07-2007, 03:28 PM   #7 (permalink)
Rebooting
Seems to me a software issue more than a Hardware problem.. !! Try Installing updated Drivers !!
rebooting
ChotoCheeta.com
Old 07-07-2007, 03:30 PM   #8 (permalink)
Choto Cheeta .. Already Done that... Latest Drivers are already in place... but no use....
idea is offline
Old 07-07-2007, 11:57 PM   #9 (permalink)
Remove the card drivers from device manager.Change the card to a different slot.Restart and reinstall drivers.
See if it helps.
Old 08-07-2007, 12:02 AM   #10 (permalink)
Guys !! U all are great !! its done and running !!
Choto Cheeta .. Thanks a lot !!
Just got a small issue..
I am not able to Share Drive D: on Lan PC... See pic..
How can i Share it full control??
Please Help !!
idea is offline
Old 08-07-2007, 02:09 AM   #11 (permalink)
Rebooting
Glad to help !!
Try to Disable the Simple file share, go to Tools, then Folder Option, and do uncheck the option, which says, use simple file share
Now right click on the drive, and go to shareing and security, there apart from defaul X$ share, Click New Share and give a name then Click Permission, now try to add every one or ur use name there with Full permission
rebooting
ChotoCheeta.com
Old 08-07-2007, 12:16 PM   #12 (permalink)
Hats Off to you Buddy !!! Problem Solved !!
idea is offline
Gaming Controllers aquamatrix Hardware Q&A 2 24-10-2006 06:41 PM
High Speed USB Host controllers topcat Software Q&A 1 03-10-2006 02:18 AM
HDD Controllers troubleshooting techie2go Hardware Q&A 1 28-11-2005 09:09 PM
