06-07-2007, 04:22 PM
OCZ Reaper HPC PC-8500
Does anyone have the OCZ Reaper HPC PC-8500 2GB kit? Hows the performance? How does it compare to the Corsair dominator PC-8500 kit?
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
07-07-2007, 10:47 AM
Re: OCZ Reaper HPC PC-8500
^^^ If u can wait fer 2 more weeks... I'll tell u... Besides the Domin8r is currently the best...
iE6850 + TRU-120 + Antec120mm Trilite. ASUS P5K Deluxe Wi-Fi AP. 2Gb G.Skill DDR2 PC2-6400 (4-4-3-5). Sgt 250GB 7200.10... XFX 8800GTX 768MB. Corsair HX620. MX518. CM Cavalier. DELL SE198WFP. EP630.
07-07-2007, 01:28 PM
Learner
The OCZ Reaper uses Micron D9GMH (B6-3) chips, which are excellent performers, and the ram is quite good. But on the other hand The Dominator is known to use both Micron D9GMH (B6-3), and also the best Micron D9GKX (B6-25E). The chips are handpicked, and hence I will consider that the dominator's have a better probability of having higher clocking chips.
In any case, my guess is both the sticks should easily touch the 1200Mhz mark, I have a D9GMH, and it truly rocks.
@gannu_rox
but I will have to disagree with that, there are better chips than dominator's out there, like the CellShock CS2221440
07-07-2007, 04:53 PM
Agreed bosso...
With the 2 options he gav I selected d best... I know abt cellshock FYI...
OCZ Reaper was a lesser o'clocker frm wat the reviews suggest frm tomshardware...
Here...
http://www.tomshardware.com/2007/06/...ds_and_timings
And here...
http://www.tomshardware.com/2007/06/...air/page4.html
07-07-2007, 05:08 PM
Learner
yup, exactly as I thought.
09-07-2007, 09:22 AM
Ok then...thanks for the inputs...Dominator it is...
@gannu - Will wait more than 2 weeks  System is still in the planning stage...
09-07-2007, 11:05 AM
does p5b deluxe mobo support pc2-8500 series ram>>??
09-07-2007, 05:13 PM
I guess it should...
09-07-2007, 05:33 PM
well official support is 800/667/533 mhz
10-07-2007, 09:29 AM
It may not run at 1066 and may run at only 800 MHz. But you can always OC. Even the 680i LT officially supports only officially supports 800 MHz memory but the PC2-8500 modules work just fine...
10-07-2007, 12:07 PM
so let me hv a conclusion,pc2-8500 from dominatorseries/ocz reaper series is a good choice??
10-07-2007, 04:19 PM
In short, Yes...
PC2-8500 is the sweet spot in terms of price/performance ratio...
