Old 06-07-2007, 02:11 PM   #1 (permalink)
jal_desai's Avatar
Unhappy Laptop Battery Not Recharging...!
hi ppl... i have encountered a strange problem. Hope its not strange to all u ppl out there. the problem is tht my laptop battery is not recharging at all when given an AC supply. yesterday there was a power failure due to heavy rains and i was workin on my lappy. but as usual the lappy remained ON as it switched to the DC (battery) supply. i was so engrossed in work tht i used the battery fully and then after consuming the whole battery the lappy went off. Now when the power came back... the lappy's battery does not get recharged at all...!! right now i am workin solely on the AC mains. but the battery is not getting "filled up". help me guys. wat cud be the problem
my laptop is COMPAQ PRESARIO M2000
TechExplorer.in
jal_desai is offline
Old 07-07-2007, 01:27 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Laptop Battery Not Recharging...!
You need a new battery now. If you've used it regularly for over 1.5-2 years, chances are the thing is dead. Similar thing happened with my Acer laptop, when the battery died, I continued using it on AC power until it was too late. Some power fluctuations at my place toasted the circuitry and technicians couldn't fix it. I don't think what happened in my case would happen to you, but just to be safe get a battery.
The laptop battery comprises of a circuit and cells. If the battery is old, you can get the cell replaced and it's as good as new. But I think in your case the problem may be in logic board circuit. No way to fix it, if that's the case.
Sourabh is offline
Old 08-07-2007, 12:28 AM   #3 (permalink)
jal_desai's Avatar
yup i think the battery's dead. phew.. after 32 views i got 1 answer..... thnks a lot brother
TechExplorer.in
Good Laptop Battery Charging Habits? drgrudge Hardware Q&A 5 07-02-2007 09:30 AM
Laptop battery already dead?? harpoon Laptops and Netbooks 5 01-01-2007 11:13 AM
Balancing battery and power supply on laptop sakumar79 Laptops and Netbooks 5 11-05-2006 07:00 PM
