Old 05-07-2007, 09:49 AM   #1 (permalink)
Default Upgrade System Help Needed!!!!
pals...i need 2 upgrade my system,,,, so needed help....
1. which processor 2 go 4.....
x2 or c2d???
prices also.....
3800+ or e6300
and wots the price of 4800+ and e6400
2. mobo for either... amd aand intel...
no sli needed... which supports the above rpocesor good..
3. gfx card under 8ks.... for the above mobo....
thanx
angel
The Day Walker! is offline
Old 05-07-2007, 02:02 PM   #2 (permalink)
Phalanx's Avatar
Default Re: Upgrade System Help Needed!!!!
It all depends on your budget... If that's flexible then u should go for an Intel based system... C2Ds are way better than X2s, especially when u take their overclocking ability into account...
Here are the approximate prices of the hardware you asked for:
C2D E6320 -- 7500
C2D E6420 -- 8500
X2 3800+ -- 3800
X2 4800+ -- 4800
XFX 650i Ultra (for Intel Proccys) -- 6000
Asus M2A-VM ( for AMD proccys) -- 4000
Also check out the C2D E4300... It costs about 4600 and performance is better than 3800+... In fact there is not much difference in performance between E4300 and E6300... And to top it off E4300 is a better overclocker... So do consider this proccy too... Read the reviews in tomshardware and anandtech.com to know more...
As far as Graphics card is concerned go for XFX 8600GT... It costs about 7K and is an excellent card for its price....
Phalanx is offline
Old 05-07-2007, 02:14 PM   #3 (permalink)
Dark Star's Avatar
Get this .. E4300 + XFX 650i + XFX 8600 GT = 4.8+6+7 = 17.8 k The best VFM else u can wait for 22nd July for price drop
Btw no AMD as of now
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 06-07-2007, 09:52 AM   #4 (permalink)
k....
so ill fix the g-card..... xfx 8600gt...
ram takin 2gb crosier....
wots the price of .... asus p5b deluxe and asus p5kc mobos....r they good...
or the xfx 1 is good.....
and for the pro..... ill wait till 22
thanx
angel
Old 08-07-2007, 09:52 AM   #5 (permalink)
hey pals...can i get the price review of the mobo....
posted above??
plz help
angel
Old 08-07-2007, 12:19 PM   #6 (permalink)
Google Bot
Pathik's Avatar
check out overclock3d.net 4 a good review of the xfx 650i.. Good vfm board
Pathik is offline
Old 09-07-2007, 08:56 AM   #7 (permalink)
Dark Star's Avatar
Originally Posted by The Day Walker!
k....
thanx
angel
P5k costin bomb now do not get those .. Over priced... Btw get Kingston ram instead of Corsair.. Kingston has newer Elpida Chips rather than older Hynix on Value of COrsair
Old 13-07-2007, 02:45 AM   #8 (permalink)
hey pals finally i have decided....
2 go in 4 amd 4800+
mobo:- asus M2N-E mobo
transient 2x1gb ddr2 667
and galaxy 8600gt 256 mb gfx
is it ok?????
and wot should b the ideal price of the above config????
also needed a decent cabinet and 5.1 speaker system???
which 1 should i go in for..and wot is the price???
a bit info needed,, i have 3 pata hdds on my present system... so can i use all of them on my new system or not????
thanx
angel
Old 14-07-2007, 01:03 PM   #9 (permalink)
Phalanx's Avatar
I would suggest u to go for XFX instead of Galaxy... Even though chipset is same, XFX will surely perform better... Also u can be assured of a better quality product... It costs about 7K...
The prices for the rest of your hardware will be:
4800+ ---- 5.5K
M2N-E ---- 5.5K
2GB 667Mhz ---3500
Zebronics/IBall cabinet----1500
Since M2N-E has only one slot for a PATA device, you will not be able to use all your HDDs here... Although its got 6 SATA ports; which is a high-end feature right now....
Phalanx is offline
Old 14-07-2007, 02:43 PM   #10 (permalink)
Dark Star's Avatar
^^Eh.. Galaxy 8600 GT rulezzzzz... XFX do not have HDMI so u'll be having problem using HD contents Do not go for AMD btw AMD got a price cut so people plz update urself before updating other Get Intel 4300 C2D 100 times better than any AMD
Old 15-07-2007, 12:12 PM   #11 (permalink)
k..thanx pals.......4..ur review....
by the way...wots the new prices of AMD 5000+ or 5200+...cause i m thinkin of AMD only ...no intel thou it performs better......
cause after the price cuts..i cant jump 2 5000 or 5200....
and a decent cab+smps(500w) under 2500????
which 1 should i go for....
Old 15-07-2007, 12:25 PM   #12 (permalink)
Dark Star's Avatar
Old 15-07-2007, 03:36 PM   #13 (permalink)
then ill probably go in for a 5200+
any cab+smps..below 2500 (zebronics/coolermaster/antec)
Old 17-07-2007, 12:46 AM   #14 (permalink)
impossible.u can get only iball,novatech stuffs,u ll need min. 400 watt psu,zebronics being the cheapest amongst those three.single cabinet,a decent one ll be abt 1.8-2k.
u can get zebronics lava with 400watt psu @1.5K reference theitdepot.
DOTA is really addictive :D
BULLZI is offline
Old 17-07-2007, 02:51 AM   #15 (permalink)
bro...
wot is the price for zebronics bijli..and marco...
i like those 2 cabs.... and has all the extra fans and other stuff...
r these 2 cabs good enough......???
thanx
angel
Old 17-07-2007, 09:50 AM   #16 (permalink)
Dark Star's Avatar
U guys think of everything and never think of buying better cabby and PSU which are the main sole life of a CPU.. Invest in Branded CPu like COrsair,CoolerMAster, ANtec and Seven Team if you can else get at leat CM Extreme 600 watt for the sake of your system
Old 17-07-2007, 10:54 AM   #17 (permalink)
bro...
thanx
angel
invest some more money n get a better cabby as well as psu.as i hv told ny branded psu(Antec,Coolermaster,Zebronics) with min. 400-450 watt will exceed ur budget.
BULLZI is offline
Old 18-07-2007, 02:49 AM   #18 (permalink)
i cot the prices here in srt....
5000 and 5200+ not available...
5600+ = 8000
asus m2n-e = 5750
xfx 8600gt 256 = 8600++
r these prices ok?????
wot r the pricesif these in mumbai...with address....
in another thread, i read that m2ne is not a good board and has some probs....so can i confirm that ......is there any prob with the mobo or the mobo is good????
thanx
angel
Old 18-07-2007, 11:30 AM   #19 (permalink)
Phalanx's Avatar
XFX 8600 GT (Standard Version, not the XXX one or Fatal1ty or something) should not cost more than 7.5 K.... I bought it more than a month back from bangalore @7K + VAT...
Moreover if u are going to spend that much for the CPU and Mobo, I suggest u take a look @ C2D6600 and XFX 650i Mobo... This is an awesome combo and its wayyyy better than AMD combo.... The mobo costs almost same as M2N-E so u dont have to spend anything substantial there... The proccy will cost 2K more but its worth it...
Phalanx is offline
Old 19-07-2007, 01:56 AM   #20 (permalink)
bro..thats y i m askin the prices in mumbai...as i can buy the stuff from mumbai........and come back 2 srt...
so can any 1 plz help me out with the address and the prices in mumbai....
and as for the stuff... c2d6600 is 2.4 while 5600+ is 2.8
so still does c2d performs better?????? is it true????
thanx
angel
Old 19-07-2007, 02:01 AM   #21 (permalink)
Rebooting
Choto Cheeta's Avatar
E6600 will out performe X2 6000 + with little OC !!! C2Ds are very very much over clockable...
http://www.tomshardware.com/2006/07/...out_athlon_64/
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 19-07-2007, 02:22 AM   #22 (permalink)
so wots the price of e6600 before 22nd and after 22nd.....
as the prices r goin 2 fal...
adn price of xfx 650i mobo....
thanx
angel
Old 19-07-2007, 02:24 AM   #23 (permalink)
Rebooting
E6600 retails right now around 10.5k + TAX i would say P5N-E SLi over that XFX 650i, but anyway, 650i SLi is at Rs. 6.5k + TAX in Kolkata Market !!!
rebooting
ChotoCheeta.com
Old 19-07-2007, 02:38 AM   #24 (permalink)
bro,,i dont need an sli board...
plain will do..
wots the price of p5n-e mobo?
Old 19-07-2007, 03:14 AM   #25 (permalink)
Rebooting
Well Its 7.2 k + TAX !!!
rebooting
ChotoCheeta.com
Old 19-07-2007, 03:26 AM   #26 (permalink)
oh....
bro my max budget is 14 ks...for mobo+proc
cant spend anything more then that......
so ill stick 2 5600+ m2n-e (i think so)...
wot u say???
Old 19-07-2007, 08:09 AM   #27 (permalink)
Rebooting
E6420 @ Rs. 7.8 + TAX
XFX 650i Ultra 6.5k + TAX !!!
rebooting
ChotoCheeta.com
Old 20-07-2007, 02:20 AM   #28 (permalink)
hey my mumbai friends...
can any1 give me the lowest mumbai prices 4 my prods...
5600+, m2n-e, 8600gt
and the exact location cause ill come 2 mumbai 4 1 day just 2 purchase these prods....and come back...
plz help guys..
angel
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
UPGRADE NEEDED........... BUt WHAT?????? ymhatre Hardware Q&A 4 01-03-2006 07:59 AM
system upgrade readermaniax QnA (read only) 14 01-08-2005 11:19 PM
upgrade help needed!! adityaksharma QnA (read only) 1 14-07-2005 10:55 PM
system upgrade!!! karthik316_2003 QnA (read only) 7 25-05-2005 02:01 AM
