Purchased a Seagate .. SATA 7200 rpm 160 GB HDD...
It was working fine...
But when i connected another 80 GB HDD with the system.. the System was unable to boot..
when i removed my HDD the system started fine...
Now when i connected my HDD to any system that system wont boot...
Wat can b the problem?
the system isnt starting bro...
when i remove the power cable of the HDD... the system starts working...
but when i attach the power and data cable of the HDD it doesnt power on.. while the Green LED on the motherboard is also glowing...
Re: Wat happened to the HDD...?
^^ But he said system isnt even starting...Primary or secondry...no matter..
System isn't starting.
Most probably the HDD is consuming more power then his PSU can provide.
Drive is faulty I think, get it replaced.
One more thing is that when i press the power button, the processor fan starts and then turns off... means gives three four rotations only...
then nothing happens...
I hav given the HDD to the vendor for replacement..
